WiFi Optimisation on Sagemcom FAST 5364
jomo28
Message 6 of 6
I have lost count of the times I have telephoned Talk Talk for technical support. The last few calls the advisers initially focus on TV channels when I mention WiFi channels on my router.
My TalkTalk Sagemcom FAST 5364 router changes WiFi  channels, sometimes within minutes after I have manually changed them. This wouldn't normally be a problem if the new channels on 2.4 and 5 GHz were less congested.  In the router log there are multiple instances of channel hopping listed.
I was asked several times to do a factory reset, and wait .....
One adviser said he had turned WiFi optimisation off. I manually change WiFi channels, check and channel hoping continues, with the router soon changing to a different channel. Whilst we are talking I do a requested factory reset, and ask him to check and he reports back that the wifi-opimisation is still tuned off, even after a router factory reset. And the router still channel hops by itself.
Some of the advisors I have chatted with want to book an engineer to be sent round. But this shouldn't be needed with the remote software (TR-069?) that has access to the Sagemcom FAST 5364 router.
Could someone at Talk Talk please help?
5 REPLIES 5
Message 1 of 6
You're Welcome 🙂
Message 2 of 6
That's great - thanks for your help.
Message 3 of 6
Hi jomo28
Optimisation is now turned off for your router.
Message 4 of 6
Thanks Keith
Message 5 of 6
I will ask TalkTalk support to sort this for you.
