WiFi asking to log in.
Paul872
Message 6 of 6
Hello, recently changed home but the WiFi is asking me to log after I try connect to the WiFi. I have reset the router. Please help.
5 REPLIES 5
Message 1 of 6
Hi Paul,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault. Is this still happening at the moment? Have you tried factory resetting the router and then resetting this up again?
Message 2 of 6
Message 3 of 6
I was able to log in to router settings, said everything was working but it’s not. If i try load anything on WiFi it’s unable to connect to any pages.
Message 4 of 6
I’ll update it now. Yes as soon as I try connect to WiFi on my phone or tablet it asks to sign in but it says access denied. I don’t have an Ethernet sorry.
martswain
Message 5 of 6
Please be specific.
Can you connect to the WiFi using the network name and password on the router ?
Where exactly is the login request appearing, is it on a browser or pop up after you connect your device wirelessly ?
What happens on a wired connection ?
To get support, please update your community profile with your landline number.
