WiFi dropping out then starting back up??
Billymitch9
Message 3 of 3
Sick to the back teeth of sloggin it out in warzone, only to get to the final circle or so and the connection cutting out completely, then starts back up. Any body have a fix for this?
International spoon sucking champion 2017,2018,2019 and soon to be 2020
Chris-TalkTalk
Message 1 of 3
Hi Billymitch9,
Sorry to hear that you're experiencing problems with warzone. Could you answer Keith's questions and we'll be happy to look into this for you
Message 2 of 3
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
