WiFi frequencies
hampshirehog
Message 6 of 6
My WiFi from my recently received router tends to be rather slower than expected and slower than my previous router.   My phones Apps tell me it is only communicating on the 2.4Ghz band.
Ben
5 REPLIES 5
Message 1 of 6
Have you by any chance got the new Huawei version of Wi-Fi Hub, or the Sagemcom one? The Huawei one does not have the WiFi Gear icons.
Message 2 of 6
Hi hampshirehog
Have you tried factory resetting the router using the pin hole reset for ten seconds?
Message 3 of 6
Thank you for your advice.  Had already been through my new TalkTalk WiFi router but the Wi-Fi 5Ghz gear icon does not appear.
Ben
Message 4 of 6
Hi hampshirehog
I can see that Keith has posted on your thread. Keith provides really good advice on improving wireless performance.
Message 5 of 6
If you have the HG633, HG635, DSL-3782 or the TalkTalk Wi-Fi hub, they are dual-band routers & offer both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and if the HG635 a password of "admin" as well, or if the HG633, DSL-3782 or the TalkTalk Wi-Fi hub, use the unique router password (see the label on the rear of the router at the top).
HG633/635 go to:-
"Customise my wireless network"
Append "5G" to the end of the network name of the "Wireless 5 GHz SSID" field. Then click "Save".
DSL-3782 go to:-
Settings > Wireless (Wi-Fi)
Append "5G" to the end of the network name of the 5 GHz "SSID" field. Then click "Save".
TalkTalk Wi-Fi hub
Go to:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 5Ghz gear icon > Basic
Append "5G" to the end of the network name of the "SSID" field. Then click "Apply".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
Having said that, there is another approach which can be better, which is to use Band Steering. This will automatically move any 5G compatible device connected to the 2.4G band to the 5GHz band. This is available on the HG633 (V2.00), DSL-3782 (V1.10) and the TalkTalk Home Hub. To use this, leave both network names identical on each of these routers and on the HG633 you will need to additionally enable Band Steering from the initial Wi-Fi menu.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
