WiFi hub switching to default channel
rtaylor46
Message 15 of 15
I have just activated my fibre 65 service. I am only using the 5Ghz WiFi band because of congestion on the 2.4Ghz band.  The few users on the 5Ghz band are all using channel 36. I manually set my hub to channel 128 and see a perfectly clear signal in the spectrum. A few hours later and my hub has switched back to channel 36. How can that be “optimization”.  Please disable this feature and allow me to set the channels I want to use.
14 REPLIES 14
Message 1 of 15
Hi Richard
Thanks for letting us know.
Debbie 🙂
Message 2 of 15
The replacement router seems to to be stable now.
I am returning the wifi hub in the packaging provided.
Richard.
Message 3 of 15
Hi rtaylor46
WIFI optimisation is not set up on the Huawei WIFI hubs so this shouldn't change the channels.
Had the router been reset?
Message 4 of 15
Well I thought the problem had been resolved. The router ran for just over 4 days using the 5ghz channel I had configured.  Then yesterday it reverted to a default channel even though the advanced configuration says it should be using channel 56.
what is wrong with this equipment?
Message 5 of 15
Hi rtaylor46
Yes this router is also a WIFI hub, it's just a different make and model.
Message 6 of 15
Yes please that would be good.
Does the Huawei hub have similar specifications to the Sagecom?
Message 7 of 15
Hi rtaylor46
Would you like me to send a Huawei WIFI hub for testing?
Message 8 of 15
This issue is NOT resolved.
The hub now resets to the default channel after about 2 days operating on a manually configured setting.
This has occurred twice since Thursday.
Clearly the issue is not fully fixed by disabling wifi optimization.
Can someone investigate this problem and supply a fix and/or a. replacement hub
Message 9 of 15
Hi rtaylor46
I'm so glad to hear this.
If you do experience any further issues then please let me know.
Message 10 of 15
Still working ok this morning on the channel I set.
Message 11 of 15
Hi rtaylor46
This is still showing as switched off. I have saved the settings again, please can you monitor this today/this evening and let us know how you get on?
Message 12 of 15
Unfortunately the problem is not solved. The hub switched back to channel 44 this morning.
Can this be fixed permanently please
Message 13 of 15
Hi rtaylor46
The WIFI optimisation has now been switched off, please let us know how the connection compares.
Divsec
Message 14 of 15
Hi @rtaylor46 Your post has been flagged for assistance and you should hear soon but please remember that the staff here work office hours.
