WiFi issues
Richard Banks
Message 17 of 17
Hey can you help, my wife has just started dropping out every 20 mins or so. Wired connection is perfect but WiFi is rubbish, we haven’t made any changes to anything and everything I’d plugged in etc. Please help!
16 REPLIES 16
Message 1 of 17
Hi Richard
How has the connection been since your last post? Did you change the wireless channels?
Message 2 of 17
Hi @Richard Banks
@Debbie-TalkTalk asked me to help you, which I did way back in post #2. However, you did not reply to me, so I assumed that you did not want my help. As I do this totally free of charge in my own time (being a customer, not a TalkTalk employee), I do not have the time to help people on complex issues, unless they request it.
The offer is still there to help you if you require it.
Message 3 of 17
Message 4 of 17
I haven’t changed anything at all 🤯
Message 5 of 17
Hi Richard
If there is wireless interference then yes. Did you change the wireless channels?
@KeithFrench provides really great advice on improving wireless performance, could you help please Keith?
Router is Sagemcom WIFI Hub and WIFI optimisation has been switched off.
Message 6 of 17
If you think that will improve things then yes. My observation is that we are only having this issue since the lockdown started again, would more people working at home contribute to the problem?
Message 7 of 17
Hi Richard
Would you like me to send the Huawei WIFI Hub for testing to see how the connection compares with this router?
Message 8 of 17
Yes
Message 9 of 17
Hi Richard
Are wired connections still working ok?
Message 10 of 17
Debbie, it’s rubbish again today, I have rebooted everything but it’s made no difference could you check it out please?
Message 11 of 17
Hi Richard
Ok, please can you continue to monitor the connection and let us know how you get on.
Message 12 of 17
It seems okay this morning, we have 3 laptops and 5 mobiles running off of it.
Message 13 of 17
Hi Richard
 I have now switched off the WIFI optimisation. Please can you test a few different wireless channels to see how the connection compares?
Change your wireless channel
Message 14 of 17
Debbie unfortunately your message went into my junk Mail so I’ve just picked it up. I have reset the box as requested, all of the internet, WiFi etc keeps dropping out now, tricky when you are working and schooling at home.
all the best
Rich
Message 15 of 17
Hi Richard
I can see that you are using the Sagemcom WIFI Hub. Please can you factory reset the router using the pin hole reset for ten seconds, I can then try and connect to your router.
Message 16 of 17
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
