WiFi keeps dropping off and 2.4 GHz signal not working
AndyHunter
Message 8 of 8
I have a TalkTalk super router HG635 and over the last 3 weeks the 2.4GHZ wifi keeps dropping so it makes it impossible to stream or use the internet. I have done a factory reset of the router and set it up again but the problem still occurs. The 5 Ghz wifi seems stable but not so many devices use this.
Any help would be appreciated as it's very annoying.
7 REPLIES 7
Message 1 of 8
Message 2 of 8
thanks for the quick response Debbie, will let you know.
Message 3 of 8
Hi Andy
I have ordered you a replacement router for testing, please allow 24-48hrs for this to arrive.
Message 4 of 8
Hi OCE_Debbie
I have updated my profile.
Thanks to everyone for replying.
Message 5 of 8
Hi Andy
  • Name
  • Telephone number
  • Alternative contact number
paulshent
Message 6 of 8
Hi.  First thing. Please update your profile s it contains your full name and telephone number to allow an OCE to locate your account.
Do not post that info on this thread for security reasons. Just say completed when you have done this.
The HG635's although a great little router are becoming end of life. Sounds like your hardware is failing.
An OCE will pickup this ticket during Monday to Friday.  They may well / Should offer to send a new router to you.
Skynet_TX
Message 7 of 8
Hi @AndyHunter,
You could try changing the channel that your router broadcasts the 2.4GHz Wi-Fi signal on, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested.
If trying this makes no difference then it may indicate an issue with the router, the staff here would be able to help with that.
