WiFi only working on certain apps
aledthomas
Message 2 of 2
WiFi will only connect to certain apps, all safeguards have been turned off to overcome this with no luck. Had the WiFi 7 months and issue has just started. Apps/phone/tv aren't the problem as will work using only mobile data.
Any help will be appreciated?
Cheers Guys,
Aled
1 REPLY 1
Message 1 of 2
Hi Aled
  • Name
  • Telephone number
  • Alternative contact number
