Wifi 6 Router to replace HG633
LCFC58
Message 7 of 7
I have had the HG633 router since upgrading to Fibre a few years back and would like to upgrade it to a new reasonably priced Wifi 6 compatible router. Could someone provide some suggestions of which Routers are recommended? Or point me in the direction of any previous threads covering this, as I can't fine any.
Thanks in advance for any help.
Kev.
6 REPLIES 6
Message 1 of 7
No, but first off do you have any devices that can support WiFi 6 or 6E?
Message 2 of 7
Hi Keith,
Thanks for the reply, I hadn't even heared of Wifi 6E !! I'm looking for a good all in one Modem/Router Combo not sure if there are any reasonably priced Wifi 6E versions out there, do you have any suggestions for a Wifi 6 version below £125?
Thanks,Kev.
Message 3 of 7
Hi Chris,
I wouldn't say "Google is your Friend" is useful advise !!!
I'm still looking for further recommendations 🙂
Chris-TalkTalk
Message 4 of 7
Hi Kev,
I can see that you've had some useful advise, please let us know if you need any further assistance
Message 5 of 7
Google is your friend, other search engines are available.  🙂
Message 6 of 7
If you want to go to WiFi 6, I would not advise WiFi 6 itself, but the game-changing newer WiFi 6E, as this includes a third band in the 6GHz frequency spectrum. I can't see that any WiFi 6 router or device can be upgraded to WiFi 6E by a firmware update. I do not think that there is even an Amazon Eero that supports WiFi 6E and of course, to take advantage of this, you would need devices that support 6E as well.
