Wifi Disabled on new router
jonnyt17uk
Message 11 of 11
Hello, after about 3 months of fault free fibre, the wifi has suddenly stopped working. Wired works fine, but the router is no longer discorable as a wireless network. I have connected to the router wiredn(192.68.1.1) and it says the wifi is 'disabled'. I have tried a factory reset without any success. Reading through the forum it looks like i have a router from a faulty batch. Please see the screen shots below.
Can you please advise ASAP.
Many Thanks
Jonny
10 REPLIES 10
rrarra
Message 1 of 11
My wifi is disabled and reboots and clicking button will not re enable running
TalkTalk Wi-Fi Hub
version SG4K10001E00t
need this fixed else I will move to another vendor. The call center keeps telling me to call back.
Message 2 of 11
Hi jonnyt17uk
Message 3 of 11
Yes if you could send a replacement router that would be great. Can you please let me know when it has been dispatched. Thank you. Jonny
Message 4 of 11
Hi jonnyt17uk
Apologies for the delay.
I can send a replacement router, would you like me to arrange this?
Message 5 of 11
Thankyou Freddie. I appreciate your help.
Message 6 of 11
Hi @jonnyt17uk
This has been escalated for OCE support by @Divsec for you. They will reply on here.
I think that it is a defective router as you have tried a Factory Reset and disconnecting from the power for 30 mins to clear the session.
IMPORTANT
Message 7 of 11
I'm still getting status 'down' for each. When searching for the network on my phone tec, the network is notfound on the list.
fre55die
Message 8 of 11
Hi @jonnyt17uk
As @Divsec suggested have you tried clicking on the WI-FI button and when in the settings section go to "MANAGE ADVANCED SETTINGS".
From there click on the cog symbol on each of the WI-FI channels and add 2.4 then 5.0 after each respectively or totally rename them in the SSID boxes, personally I have changed mine to TT 2-4 and TT 5-0. This will separate the channels and see if both are disabled or just one. This will also help you to identify which is giving the best signal on your wireless devices.
Message 9 of 11
Hi, Thank you for replying.
If I hit the 'See Wifi Settings' I get to the screen shown below. If I toggle the enable/disable wifi button, it still shows wifi disabled. My symptons look identical to those discussed here https://community.talktalk.co.uk/t5/Broadband/Wifi-Disabled/td-p/2214049 which ended up being a faulty router. Can anyone confirm this and advise how to get a new one?
Divsec
Message 10 of 11
Hi Jonny, did you try to click on the button at the bottom of the my WiFi section. It should take you to series of options where you can enable WiFi. Good luck
