Wifi Disconnects when in standby
Aaron_Campion
Message 3 of 3
So over the past week ive noticed an issue that when i put a device in standby mode it disconnects from the wifi and then has trouble connecting again when turnt back on.
This is happening with my ps5, xbox, laptop and smart tv
Any ideas
Message 1 of 3
Hi Aaron_Campion
Which router are you using? (make and model)
Skynet_TX
Message 2 of 3
Hi @Aaron_Campion,
Wi-Fi interference could possibly be a cause for your devices struggling to connect, however interference would often also cause issues with your Wi-Fi signal when the devices were in use as well.
You can use free smartphone Apps like this to see what channels are being used within range of your smartphone, if it looks like your router is having to fight with other strong signals on the same, or similar, channels you could change your router to use channels that are less congested.
The Support Team here probably won't be around now until Monday, but they should be able to respond to this post early next week to help.
