on 19-12-2021 08:20 PM
Hi there,
I was wondering if there was a problem with the wifi on this particular router? The only reason I ask is that over the last few weeks my phone (Samsung Galaxy S20FE) and my daughters phone (Apple iphone 12) keeps dropping connnection.
My phone shows wifi is "connected without internet" on both 2.4ghz and 5ghz bands and the iphone is showing an odd privacy notification and doing the same thing - connects to wifi but no internet? Wifi encryption is WPA2 Personal on both bands.
The internet connection is fine and all other devices seem to work ok for now.
So....is there a problem?
Many thanks
on 31-12-2021 10:18 AM
Hi Debbie, thanks for your reply. Well I'd believe that if the router was showing the line was only capable of between 30 and 35 meg BUT it's showing the line can do max 60meg download, the engineer says it's capable of that yet here I am stuck at 35.
Nay bother, if it doesn't get sorted I only have 3 months to put up with it then I'm moving like I very nearly did last time. But this time your sales guy won't sweet talk me into staying, he'll be shut down immediately.
Many thanks
31-12-2021 09:31 AM - edited 31-12-2021 09:32 AM
Hi Techman81
Apologies for the delay.
The line is in sync at 35.5mb. I've checked and the predicted speed range we have showing for your line is between 57 and 37.1mb, with a guaranteed minimum speed of 32.2mb (on Fibre 65)
on 30-12-2021 10:30 PM
So I had an engineer out today. He went straight to the Master said it was ancient and changed it for a new one with built in xDSL filter. He also noticed whoever was in the master last bodged it with electrical wiring!
Anyway, he did his line tests and said his equipment was showing speeds of 60 DL and 11 UL and all is good.
It's not....
Router is now showing Actual DL of 35 with Max Attainable of 60. Upload is ok.
When I run the Line Test in Service Centre it says there's a fault and wants to do a full test but before I do I thought I'd come on here see what you say.
Also want to check what package you have me on as I should be getting between 50 and 60 Actual according to the engineer and his testing equipment so I hope I'm not on Fibre35 as I should also have a speed boost too as per my last contract renewal.
24-12-2021 08:13 AM - edited 24-12-2021 08:45 AM
@Jose7499, staff only reply to the original poster.
Please return to the message board and click on start a topic to open a new thread.
You also need to complete your community forum profile details for TT staff to identify your account. Add your landline phone number there - go via your avatar/name; settings; launch profile wizard.
on 24-12-2021 06:48 AM
When I first took TT fibre my Actual and Max were within about 2mbps of each other and was synching at about 60mbps. Now with every fault that I've had in the past and been corrected it seems to be dropping and dropping.
on 23-12-2021 03:16 PM
I've sent a PM requesting some info.
on 23-12-2021 03:08 PM
Hi Karl, thanks for replying. Yes please if that's possible. If the difference was around 5mbps I wouldn't bother but 24mbps difference is huge. If it's saying max attainable is 58mbps I should be getting over 50meg surely?
Many thanks
on 23-12-2021 02:55 PM
My bad, yes it is, the speed is on the lower end of the estimate.
The next option is to log this out to Openreach for an engineer to investigate. This however will not be until after the Christmas period, would you like to progress with this now ?
on 23-12-2021 02:50 PM
Hi Karl, it's the sync speed difference I'm querying. Why there's a massive difference, 24mbps in fact, between my Actual Line Rate and Max Attainable. To me it looks like a fault on the line or my line profile is incorrect.
When I first took TT fibre my Actual and Max were within about 2mbps of each other and was synching at about 60mbps. Now with every fault that I've had in the past and been corrected it seems to be dropping and dropping. So I'm guessing either I've been banded or on the wrong profile?
on 23-12-2021 02:36 PM
Tests are still clear.
Do you see the issue with a wired connection or just from devices using Wi Fi?
on 23-12-2021 02:09 PM
Hi Karl thanks for your reply. It's plugged into the master socket test socket. No changes.
on 23-12-2021 09:32 AM
Does your master socket have a 'Test Socket' ? If it does, can you connect the router directly to this with a filter.
on 22-12-2021 08:43 PM
Hi Debbie,
I've received the new router and installed it, thank you.
The stats are more in depth. I can see I'm on Showtime and not an Error correction profile which is good.
However my actual download speed is showing 35mbps and Max Attainable is showing over 57mbps? Why is there such a big difference? My package is Faster Fibre with a Speed Boost so equivalent of the Fibre65. According to the data the router is showing, there is no errors so wondering why my Actual speed is so low?
Many thanks
on 20-12-2021 10:06 AM
Hi Kaylee
on 20-12-2021 09:40 AM
Hi Debbie, thanks for your response. It can't hurt to try a different router for testing purposes.
So yes please, if that's possible.
Many thanks
Kaylee
on 20-12-2021 07:23 AM
Hi Techman81
Would you like me to send a different make and model of router for testing to see how the connection compares?
on 19-12-2021 10:39 PM
Hi, thanks for replying. I believe it's the Sagemcom model number FAST5364 3.00.
It's intermittently dropping so sometimes it's fine and other times it just won't connect properly. But just to make clear, both phones are saying they're connected to wifi (either band) but showing limited/no internet. Router stats show NO disconnection.
19-12-2021 09:24 PM - edited 19-12-2021 09:25 PM
Hi @Techman81,
What model of router do you have (if you have a Wi-Fi Hub it will be Sagemcom or Huawei) ?
Are the other devices that are working ok wired or wireless (or both) ?
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
