Wifi Hub is blinking Amber whilst Open Reach Rooter is green
Apostolos
Message 23 of 23
I recently upgraded to the Ultra fast Fibre. I had a new SAGEM Wi Fi Hub installed together with an Open Reach Hub. I has to restart it couple of times within this week as it was stuck. Today suddenly the WiFi Hub is blinking amber continuously, but the internet light on the Openreach Hub is on. Could you assist. Thank you
22 REPLIES 22
Message 2 of 23
Hi Apostolos
Thank you, you too 🙂
Message 3 of 23
Great! I will send it ASAP and write on top of the box "New Hub not for recycling 😃"
Have a great Bank Holiday break!!
Message 4 of 23
Hi Apostolos
Thank you. The returns bag will just send the router back to our warehouse.
Message 5 of 23
Hi there. Yes could I use it? ( I thought is for recycling 😊)
Message 6 of 23
Hi Apostolos
Did you receive a pre paid returns bag with the replacement router?
Message 7 of 23
Great! Could you please confirm the address and the way to send it back? For example could I send it class 2 signed?
Thank you
Message 8 of 23
Hi Apostolos
Thanks for keeping us updated. I'm glad to hear that this is now working.
"I have the new modem arrived. I can wait couple of days to see if everything goes smooth and send it back to you?"
Yes please, thank you.
Message 9 of 23
Hi all,
Final update the issue was resolved. But here is the trick. It wasn't TalkTalk modem the issue but the Open Reach modem LAN port, which for a very strange reason was accepting the TV's signal but not the modem's one 😕.
Anyway the Open Reach guy was super useful, had a new Open Reach modem with hIm which he plugged it in and voila solid white lamp and hub working fine.
2 notes for you guys:
- Please correct the part in the TalkTalk hub description that says solid white lamp even if not connected (it created a lot of confusion)
- I have the new modem arrived. I can wait couple of days to see if everything goes smooth and send it back to you?
Finally huge kudos to the team @Michelle-TalkTalk @Debbie-TalkTalk @Karl-TalkTalk @martswain for the effort to get my issue resolved.
Cheers guys
Message 10 of 23
Hi Apostolos,
Ok thanks for the update and please let us know how you get on.
Message 11 of 23
Hi there,
Latest update is that I had a call from Talk Talk and I have an engineer's appointment booked for tomorrow 27/05. The interesting part is that I told them we had a discussion within the community and a new router is on its way, but they responded there isn't any router ordered for you. They have a broadband authentication fault recorded which needs an engineer.
Of course the engineer is more than welcome to investigate but with an amber light blinking day and night I don't think he can do much.🙂
Message 12 of 23
Hi Apostolos
Message 13 of 23
Hi Debbie
Much appreciated. Fingers crossed it will resolve the issue.
I am working from home and relying in my phone data at the moment..
Thank you
Message 14 of 23
HI Martin,
I swapped many cables but still the LAN light was off. Also, I connected my Talk Talk TV box and Smart TV straight to the Open Reach Hub and all played flawesly.
I am connecting the Open reach Hub to the Talk Talk Hub through the red WAN port.
I guess the TalkTalk Hub is not starting at all.
Thank you
Message 15 of 23
Hi Apostolos
Message 16 of 23
@Apostolos
Try another ethernet cable between the Openreach device and your HUB.
What socket are you connecting to on the HUB ?
Message 17 of 23
Hi Michelle,
Yes confirmed. The router is unresponsive stuck to amber blinking.
Thank you
Message 18 of 23
Hi Apostolos,
Thanks for the update. Just before we send a replacement router, can I confirm if you have also tried factory resetting the router and then setting this up again?
Message 19 of 23
It is updated. By the way I made a simple test by my own. I connected my Smart TV via ethernet straight to the Open Reach Hub , the Lan light was on and it worked. It had internet.
So the problem is with the Talk Talk Hub.
Thank you
Message 20 of 23
Hi Apostolos,
  • TalkTalk Telephone number
