Wifi Hub keeps losing its wifi capabilities
jimmymumu
Whizz Kid
Message 25 of 25
Had my Wifi hub for ages and as a rule i can't fault it but lately I'm finding my phone connected via mobile data but not constantly. It's not just me, my wife and daughters too. I've logged in to the router and everything is as it should be, all band 1 and 2 set as it should be and it is affecting both bands 2.GHz and 5 GHz. I've reset the router and it made no difference. Any help please
24 REPLIES 24
Message 1 of 25
Thanks for the update 🙂
Message 2 of 25
It was returned this week and i have the proof of postage too. Thanks
Message 3 of 25
Thanks for the update and I'm glad to hear that the connection has improved. Yes please 🙂
Message 4 of 25
This is a huge improvement. Do i return my Hg633 in the return bag? The reason i ask is that the HG633 does not work with my set up at all, constant drops in speed etc
Message 5 of 25
Hi jimmymumu
The Huawei WIFI hub is on its way, please allow 24-48hrs for this to arrive.
Message 6 of 25
Yes please. I'll be sure to return it. Thanks for all your help
Message 7 of 25
Ok, would you like us to send the Huawei Wifi Hub instead for testing purposes to see how this compares? This is different to the HG633 router. We would also send a router returns bag so that one of the routers can be returned.
Message 8 of 25
No not at all! I'm using my Sagecom WiFi Hub. I have a spare HG633 but it is totally unreliable. The HG's don't seem to work very well for me but the Hub is normally flawless
Message 9 of 25
Can I just confirm, have we recently sent you a different router for testing purposes?
Message 10 of 25
Thank you.
Message 11 of 25
Thank you for confirming this. It is back to the OCEs then, as I can't help with this as it could be a faulty router. I will ask them to get involved again.
Message 12 of 25
The drop in speed does affect both types of connection simultaneously yes.
Message 13 of 25
What I am still trying to confirm, does this affect wired (Ethernet) connections, because if it does, the resolution is different?
Message 14 of 25
It was something i became aware of over the last couple of nights. When i use talktalks speedtest, it seems to fluctuate between 27-33mbps when normally it's around 47mbps but can drop lower and upload is between 4-5mbps. It returns to normal after midnight and on connections is fine the rest of the time. The losing of wireless is really intermittent and will go a day or so before it loses it again. It may happen more often but I'm not sitting there watching for it dropping, just when either my tablet or phone loses connection
Message 15 of 25
I am confused, in post 5 you said:-
"I don't lose wired connection at all just wifi."
and in your last post you said:-
"My wired internet does seem a bit unstable at night"
So which is the problem?
Message 16 of 25
Yes please if you wouldn't mind. My wired internet does seem a bit unstable at night, upload speed is often below 5mbps and download drops to around 27mbps
Message 18 of 25
Thanks @Debbie-TalkTalk
@jimmymumu do you want me to send you some information regarding the use of WiFi analysers?
Message 19 of 25
Hi jimmymumu
I've now switched off the WIFI optimisation.
@KeithFrench
Message 20 of 25
OK, thanks for that, I would think it is WiFi interference as per my earlier post.
Before investigating this, however, you will need to ask TalkTalk in your next reply to disable their remote diagnostic utility called "WiFi Optimisation". This has the power to change any WiFi setting in the router that I may suggest you change.
