Wifi Hub keeps losing its wifi capabilities
jimmymumu
Whizz Kid
Message 25 of 25
Had my Wifi hub for ages and as a rule i can't fault it but lately I'm finding my phone connected via mobile data but not constantly. It's not just me, my wife and daughters too. I've logged in to the router and everything is as it should be, all band 1 and 2 set as it should be and it is affecting both bands 2.GHz and 5 GHz. I've reset the router and it made no difference. Any help please
24 REPLIES 24
Message 21 of 25
I don't lose wired connection at all just wifi. When everything is working in harmony, wifi is normally almost as fast as wired. Despite the problem, when wifi works, it still works well.
Message 22 of 25
Hi @jimmymumu
So you say that you lose the wireless, do you lose the wired connections as well? You say that the speeds are very similar, but that is presumably when everything is working OK. Please can you clarify the actual problem?
Message 23 of 25
It is the Sagecom Wifi Hub version SG4K10002816t. My Cabled and wifi speeds show very little difference in speed and at the moment I'm not suffering from any other internet problems.
It started a less than a week ago and there are no new or changed electrical devices in the home. I noticed this morning that my phone was using 4g instead of wifi and at that time of the morning i would have been the only one connected to the network. We have no devices are are run on a timer either and as far as I'm aware only happens intermittently. The light on my router shows a constant connection and that only changed when i reset the router this morning. After the usual 2 minute or so connection, my wifi which was failing before, worked fine. If there was electrical interference, what's the chance of me rebooting my router at the exact time the interference stopped?
Message 24 of 25
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using? If it is a hub, there are two of them & they are different.
