Wifi connection dropping
simhub
Message 11 of 11
Hi, I need some help please.
For a few months now we've been having problems with devices losing their wifi connection to the TalkTalk router.  It happens at the same time for all (or sometimes almost all) devices on wifi, and it happens for devices connected to 2.4GHz and 5GHz bands (which have separate SSIDs).  My PC is wired over ethernet and is never affected.  Turning the router off and on again always resolves the issue.
I'd love to tell you what router I have but it doesn't seem to say anywhere on it.  It's black and covered in holes!
What can I try to fix this please?
10 REPLIES 10
Message 1 of 11
The Huawei hub has been ordered for you.
Message 2 of 11
Thank you for getting back to me so quickly Michelle.  Yes, a Huawei Wifi Hub would be wonderful please.
Simon
Message 3 of 11
Hi Simon,
I'm really sorry but there has been a delay with the new firmware as further testing is now required. Would you like us to send a Huawei Wifi Hub in the meantime?
Message 4 of 11
Hi Michelle
This problem has not gone away yet unfortunately.  Can you please confirm when the firmware update is due, and how I can check whether it has come through?
Simon
Message 5 of 11
Hi Simon,
Ok thanks for confirming. We should be hopefully starting to roll this out at some point this month so your router should be automatically updated.
Message 6 of 11
Hi Michelle
That's great, thank you.  I will wait until the new firmware first and maybe we'll try a new router if that doesn't fix it.
Simon
Message 7 of 11
Hi simhub,
Thanks for the additional update. This particular issue should be resolved when the new version of firmware is rolled out later this month. Would you like us to send a Huawei Wifi Hub or would you prefer to wait for the new firmware?
Message 8 of 11
OK, profile updated.  I've had another look and the router is a SagemCom FAST 5364-3.T8.
To clarify what's happening, all devices connected to wifi will sometimes lose internet access and give a DNS error.  They are still connected to the wifi but can't access the internet.  My PC (which is connected over ethernet) continues to work.
Thank you for any help.
Message 9 of 11
Hi simhub,
  • Name
  • Telephone number
  • Alternative contact number
martswain
Message 10 of 11
If you pull out the WiFi password card on the back, the manufacturer name will be revealed.
