on 26-12-2021 10:21 PM
Unable to get wifi to enable on router. It shows as on with the sliders but remains disabled. Tried resets but no good. Faulty router i think.
see attached screen shots.
Appreciate some help and a new router.
on 29-12-2021 03:03 PM
It does sound like a fault with the router then so the replacement router so solve the problem
on 29-12-2021 01:09 PM
No. Tried from a few phones. Echo show and a pc . Non of them can see the network. . Wired pc's connect to the net nobother.
on 29-12-2021 01:05 PM
And if you check for the router from one of your devices it doesn't show?
on 29-12-2021 11:54 AM
I am on fibre with an openreach modem connected to the TT wifi hub but all lights are on and seem to be working. Just the wifi remains disabled in the wifi hub ?
on 29-12-2021 11:30 AM
OK, thanks for letting me know. If you've tried resetting the router to factory default setting then unfortunately I can't think of anything else to try
on 29-12-2021 11:21 AM
Wifi still off. Can connect with wired devices but no wifi. TT are sending a new router .... Fingers crossed. Is there anything else i could try while waiting.
on 29-12-2021 07:56 AM
Hi Geoff602,
How are you getting on, are you still experiencing the same issue?
on 26-12-2021 10:27 PM
Hi @Geoff602,
If you have tried a factory reset (by holding in the reset switch on the back for over 10 seconds) and it is still not allowing you to enable it, then it is likely to be a faulty router. The staff here on the community won't be around until Wednesday 29th, so you may get faster support from the phone or live chat teams (Christmas opening times shown here).
For one of the TalkTalk staff on this community to be able to look into this when they return, you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
