Wifi doesn't reach to attic bedroom
Melissah773
Message 3 of 3
I recently moved house, myself and my 2 daughters are gamers. Unfortunately they can't even use their xbox in their bedroom because it's up in the attic, I bought a plug in wifi booster which makes the tiniest difference if any at all. What can I do? Any advice welcome.
Message 1 of 3
A single unit WiFi booster will only be able to re-broadcast the speed it receives, so even if the signal it sends out is strong, throughput speed will not increase.
If that is what you have, move it to halfway between router and attic and see if things improve.
The extender in the TT shop transfers the full speed at the router to the extender over the home power cables and then uses its own WiFi transmitter in the room where you place it.
ryanhavenhand
Chat Champion
Message 2 of 3
I had the same problem, I use this - https://accessories.talktalk.co.uk/productdescription/38
