Wifi is working but it won’t connect to any devices.
20megan01
Message 4 of 4
I have got my wifi 2 months ago. I’ve had an incredible hard time setting it up, finally 2 engineers after, I had wifi! Yay, end of the problems? Nope! Now my wifi has stopped connecting to any devices after only 5 days off using my wifi! Just says “incorrect wifi password” when it’s definitely correct. I’ve went though to the service centre and done all them steps, still nothing. I’ve factory reset and still nothing. Any tips? Thanks all
3 REPLIES 3
Message 1 of 4
Hi 20megan01
I'm sorry for the delay.
Are you still experiencing this issue?
Message 2 of 4
Hi, how do I do this? I’m connected through my Talk Talk TV but that isn’t working either. I don’t have a space on laptop to connect. Sorry I’m clueless when it comes to all this!
martswain
Message 3 of 4
Connect to the router with an ethernet cable, log in at 192.168.1.1 using the OTHER password,  go to the WiFi settings page and check the WiFi password box.
