Wifi not working on Sagem hub
martyboy49
Message 19 of 19
Since yesterday I cannot connect to wifi on any of my ipads or iphone. Wired internet connection is fine. I have tried resetting the network settings on my ipads and i have pushed the reset button on the hub.
Currently all I get now is "incorrect password" when trying to log in to my network. Yes I am using my default password, which I can see on my wifi hub admin page.
can anone help?
18 REPLIES 18
Message 1 of 19
Hi martyboy49
That's great, thanks for keeping us updated 🙂
Message 2 of 19
I am pleased to say new router you sent is working well and both 2.4 & 5Ghz channels operational.
Many thanks
Message 3 of 19
Hi martyboy49
Message 4 of 19
Yes please.
Many thanks for your help.
Message 5 of 19
Hi martyboy49
I can send a replacement router for testing, would you like me to arrange this?
Message 6 of 19
UPDATE: 2.4GHz frequency seems to be working ok now. Unable to join 5GHz frequency however due to the "incorrect password" message still.
Managing ok with the 2.4.
Message 7 of 19
OK, keep us posted. I have flagged this to the support team for you and they will pick up on it when they are back online on Monday.
Message 8 of 19
Yes everything was fine before this issue. Never had any issues with wifi. Yes I gave it 30 seconds before resetting.
Never seemed to be an issue in finding my network. The issue was connecting to the network.
Update: at the moment i am connected on 2.4 at the moment.
Just monitoring if it remains stable.
Message 9 of 19
Oh dear, sorry to hear that. Can we just rewind a bit? You said this started yesterday, how long was it all working OK before then? When you reset the Hub did you give it about 30 seconds or so in doing it? Other than that it seems that there is a fault, but what puzzles me is that it is clearly transmitting a signal if the SSIDs are visible.
Message 10 of 19
No. lost the network again. lasted for about 3 mins.
Message 11 of 19
Hang on. 2.4 just connected at last.
Message 12 of 19
Changed SSID names. Checked network password and tried 2.4 & 5 frequencies. Still "incorrect password" message for both
Message 13 of 19
Login in to the router and click on See Wi-Fi settings, then scroll down and click on Manage advanced settings. Next click on the tool icon in the top right next to Wi-Fi 5GHz. Now just add some separate characters at the end of the existing SSID name - just "5" will do. You can also check there that your password is what you think it is. Then click apply at the bottom.
Once your router has saved those settings then your iPads should be able to identify the two bands separately. Choose the "5" one and try again.
Message 14 of 19
Ok I have found out how to change SSIDs and have a different name for each frequency. Still unable to connect
Message 15 of 19
Yes Ipads are see my network OK with a strong signal. How do I give different names to the SSADs?
My sky box has a wired connectio and this is ok. Nothing else on wifi
Message 16 of 19
I take it your iPads are "seeing" the wireless network OK? Have you tried giving separate names (SSIDs) to the 2.4GHz and 5Ghz SSIDs? Are any other devices connected at all?
Message 17 of 19
Thanks, yes I am aware the admin password is different. I can access the admin network hub page and I can see the wifi network password. When I enter the wifi password I still get "incorrect password" message on ipads
Message 18 of 19
The network password and the router admin password are not the same, check the removable tab and the sticker on the back of the unit respectively.
