Wifi
Amb83
Message 3 of 3
For the last month my wifi stops working for a minute or 2 and is back up and running again, the wired connection isn't affected just wireless.
This is extremely annoying as my son is trying to do his live lessons on the laptop but keeps getting kicked out, plus he gets kicked out of ps4 party's because of this issue as well and obviously our mobiles will not pick up wifi during these dropouts.
Why is this happening? I've seen a lot of people having this problem but no answers to sorting it out, I've done the diagnostic checks and it says everything is up and running fine when clearly it isn't.
Message 1 of 3
Hi Amb83
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 3
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
