Wired Connection High Latency In gaming Desktop
carmenmathews12
Message 27 of 27
Hi can anyone help lately my son has been complaing if high latency in games, its only started to happen recently and also WiFi signal on mobile devices seems to be non exsistent. With connection disconects etc but there is no issue in service center or live connection test. Speeds are fine in speedtest also when tested wired
Here below is Traceroute and ping;
C:\Windows\system32>ping google.co.uk
Pinging google.co.uk [142.250.187.227] with 32 bytes of data:
Reply from 142.250.187.227: bytes=32 time=85ms TTL=117
Reply from 142.250.187.227: bytes=32 time=83ms TTL=117
Reply from 142.250.187.227: bytes=32 time=86ms TTL=117
Reply from 142.250.187.227: bytes=32 time=67ms TTL=117
Ping statistics for 142.250.187.227:
Minimum = 67ms, Maximum = 86ms, Average = 80ms
C:\Windows\system32>tracert google.co.uk
Tracing route to google.co.uk [142.250.187.227]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 66 ms 61 ms * host-92-14-224-1.as13285.net [92.14.224.1]
3 76 ms 76 ms 76 ms ae50-ner002.msp.as13285.net [78.144.1.35]
4 75 ms 66 ms 44 ms ae50-scr002-msp.as13285.net [78.144.1.34]
5 * 68 ms 65 ms ae63-scr102.loh.as13285.net [78.144.1.132]
6 68 ms 78 ms 74 ms host-78-144-4-35.as13285.net [78.144.4.35]
7 62 ms 69 ms 84 ms 209.85.248.229
8 70 ms * 78 ms 142.251.54.47
9 67 ms 79 ms 74 ms lhr25s34-in-f3.1e100.net [142.250.187.227]
Trace complete.
26 REPLIES 26
Message 1 of 27
Hi Carmen
If you could switch the router off at the power supply (wall) just for 30 mins.
Thanks again,
Message 2 of 27
Hi Debbie,
Just press the power button on router to power down?
Carmen
Message 3 of 27
Hi Carmen
Please can you power down the router for a full 30 minutes and then run a speed test?
Yes you can also change the SSID's after the power down.
Message 4 of 27
Hi Debbie,
Just one issue on router page upload speed says 19.53 Mbps but on a test wired its only coming as 9mbs.
Also is it okay to change SSID name so I know if its 2.4Ghz and 5ghz in router configuration?
Carmen
Message 5 of 27
carmenmathews12
Message 6 of 27
Just posting to let you know that I recieved the new router and will test it out and keep you updated
Carmen
Message 7 of 27
Hi carmenmathews12
Apologies for this.
carmenmathews12
Message 8 of 27
Thanks Debbie will try it once received, also on mobile speeds really really slow literally unusable
Message 9 of 27
Hi carmenmathews12
The Huawei WIFI hub is on its way, please allow 24-48hrs for this to arrive.
Message 10 of 27
Hi Michelle,
Yes you can if you think it would improve things I dont mind, But chris already sent one out with a new firmare compared to the old one I had.
Message 11 of 27
Ok, would you like us to send a Huawei Wifi Hub for testing purposes to see how the connection compares? We would also send a router returns bag so that one of the routers can be returned.
carmenmathews12
Message 12 of 27
So just an update over the weekend, gaming latency has been terrible literally unplayable, download speeds have went to 20mbs from 80mb wired which I've never seen before. Just not good enough since made the switch? any idea what could be causing this?
Message 13 of 27
Hi Michelle,
Yes the test was connected with ethernet cable on desktop
Message 14 of 27
Thank you. These results looks better than the previous results. Was this test completed wired?
carmenmathews12
Message 15 of 27
Here is router information Michelle;
Hardware Version FAST5364 4.00
Software Version SG4K100130
GUI Version 5.6.1
Pinging google.co.uk [142.250.200.3] with 32 bytes of data:
Reply from 142.250.200.3: bytes=32 time=21ms TTL=117
Ping statistics for 142.250.200.3:
Minimum = 21ms, Maximum = 21ms, Average = 21ms
Tracing route to google.co.uk [142.250.200.3]
2 21 ms 22 ms 23 ms ae50-ner002.msp.as13285.net [78.144.1.35]
3 21 ms 14 ms 14 ms ae50-scr002-msp.as13285.net [78.144.1.34]
4 21 ms 21 ms 23 ms ae63-scr102.loh.as13285.net [78.144.1.132]
5 21 ms 20 ms 20 ms 72.14.208.22
6 23 ms 23 ms 23 ms 216.239.40.87
7 21 ms 21 ms 21 ms 108.170.234.231
8 21 ms 21 ms 22 ms lhr48s29-in-f3.1e100.net [142.250.200.3]
Trace complete.
carmenmathews12
Message 16 of 27
I replied but cant see reply showing Michelle
Message 17 of 27
Apologies, I can't connect to your router at the moment. Is this the Sagemcom Wifi Hub? We are currently in the process of rolling out new firmware for the Sagemcom Wifi Hub which should resolve this DNS issue.
I've re-checked the connection stats and the connection stats still look good. Would you mind running another wired and ping and trace route please.
carmenmathews12
Message 18 of 27
So new router has came dont see much difference, apart from in Log there is 154 pages of ;
Date/Time Severity Module Message
06.09.2021 16:06:38ErrorDNS
DNS name resolution failure (reports.crashlytics.com)
06.09.2021 16:02:18InfoWIFI
A WiFi device <C8:C2:FA:55:42:56> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
06.09.2021 16:01:38ErrorDNS
06.09.2021 15:56:38ErrorDNS
06.09.2021 15:51:38ErrorDNS
06.09.2021 15:46:38ErrorDNS
06.09.2021 15:41:38ErrorDNS
06.09.2021 15:36:38ErrorDNS
06.09.2021 15:31:38ErrorDNS
06.09.2021 15:26:37ErrorDNS
06.09.2021 15:21:37ErrorDNS
06.09.2021 15:16:37ErrorDNS
06.09.2021 15:11:37ErrorDNS
06.09.2021 15:06:37ErrorDNS
06.09.2021 15:01:37ErrorDNS
06.09.2021 14:56:37ErrorDNS
06.09.2021 14:51:37ErrorDNS
06.09.2021 14:46:37ErrorDNS
06.09.2021 14:41:37ErrorDNS
06.09.2021 14:36:37ErrorDNS
Message 19 of 27
Great thank you,will update once test new router
Carmen
Message 20 of 27
Hi Carmen,
I've ordered a replacement router, it should be with you within a couple of working days but please allow up to 5 working days
