Wireless dropouts with HG635 router
AnitaI
Message 5 of 5
I have been using talktalk fibre with the supplied hg635 router since 2014 without problem, however recently I have experienced total loss of wifi intermittently on all devices, regardless of distance from router.  When these dropouts occur, all wireless devices in the house lose connectivity at the same time, regardless of 2.4g or 5g channel - my wired devices all behave normally though.  This can happen every few minutes at times, and other times I can have hours of uninterrupted use.
Is my router ready for the bin, and if it is, is there a particular model I should replace it with?
I'm currently on the fibre 65 service.
Anita.
4 REPLIES 4
Message 1 of 5
Hi Anita
Debbie 🙂
Message 2 of 5
Hi Debbie,
After spending a few days checking for interference using wifi analyser and troubleshooting I am pretty sure I need a replacement router.
If you could arrange that it would be awesome!
Thanks, Anita.
Message 3 of 5
Hi Anita
@KeithFrench provides really good advice on improving wireless performance and I can see that he has offered to help.
It would be worth trying this first and if you are still experiencing issues then we can send you a replacement router.
Message 4 of 5
The HG635 is a dual-band router & offers both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and use the unique router password (see the label on the rear of the router at the top).
Go to:-
"Customise my wireless network"
Append "5G" to the end of the network name of the "Wireless 5 GHz SSID" field. Then click "Save".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
