Wireless no internet
markpearson35
Message 3 of 3
All was well with my internet until the past few weeks. My hub wifi wireless is staying connected to any wifi device in my house but shows no internet connection. If I reset the hub all works again fur a little while then it happens again. Anything via LAN wired is ok no issues seen. The white light on the box is always a steady white light.
Contacted the live chat but did not get very far don't think they understood my issue. Can someone please help.
Message 1 of 3
Hi markpearson35
Have you also tried a factory reset using the pin hole reset for ten seconds?
Divsec
Message 2 of 3
Hi Mark, welcome to the community your post has been flagged for assistance and you should hear during tomorrow. Have you tried a pin reset on the router?
