Wireless shows as disabled, won't enable
gryphon
Message 5 of 5
I have recently joined TalkTalk. The line was activated yesterday, I connected up the new hub at around 10:30pm and all was working fine. By the time I woke up in the morning, the wifi was disabled, despite being set as enabled.
Restarting the hub did not help. Nor did disabling and re-enabling the wireless option. Is the hub faulty?
TalkTalk Wi-Fi Hub
version SG4K10002816t
I see other posts reporting the same issue, but I was advised to start a new post instead of replying.
4 REPLIES 4
tjenkinson
Message 1 of 5
It's ok I'm probably going to switch to another router instead of the talktalk one.
Message 2 of 5
Hi tjenkinson
If you start your own thread (new message), wed love to help.
Weve found that posting in someone elses conversation makes it harder to follow when looking for an answer.
Its easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
Check your home phone number or account number are also added to your Community Profile as that will really help us to find your details quicker.
tjenkinson
Message 3 of 5
I have the same problem. I setup the router yesterday and wifi worked for a few minutes then stopped. Now I've done a factory reset and with the default wifi it's showing as turned on but also as 'current status' 'disabled'.
Message 4 of 5
Hi gryphon
I've a replacement router on the way to you.
