Work VPN connection has suddenly stopped working.
gavin327
Message 7 of 7
My employer requires me to work from home using a VPN, and provides Cisco Anyconnect (4.9.06037) for that purpose.  I have been using the VPN for around 18 months with no problems.  Throughout that time I've been using an ethernet connection to my 2018 TalkTalk router (Sagemcom 5364).
Today I was unable to connect to the VPN using the router.  However, I have been able to connect using a (much slower) wifi mobile hotpot.  Could the VPN problem have been caused by a firmware upate to the router?
I would be very grateful for your help.
6 REPLIES 6
Message 1 of 7
Hi gavin327
You shouldn't need to keep resetting the router. This will have started a new session.
If you do experience any further issues with VPN then please let us know.
Message 2 of 7
Thanks Debbie.
Your suggestion worked and I can now use the VPN again.  This is really good news.
Can you help me understand why the factory reset was required?
Message 3 of 7
Hi gavin327
Have you tried factory resetting the router using the pin hole reset for ten seconds?
Skynet_TX
Message 4 of 7
Ok, staff here should be able to pick this up tomorrow and confirm if this is a known issue.
Message 5 of 7
Thank you Skynet_TX
The firmware is indeed version SG4K100130, so that might well be the source of the problem.
Skynet_TX
Message 6 of 7
Hi @gavin327,
It could be, as new firmware is being rolled out for the Sagemcom, if you can browse to http://192.168.1.1/ and then towards the bottom of the screen it will say :
version SG4K10002816t
or
version SG4K100130
SG4K100130 is the new firmware that is being rolled out at the moment, so if you are on this version then the problem could be due to your router just upgrading to that new firmware.
However the more common VPN applications should all work ok, and I would consider Cisco AnyConnect as one of the more common VPN applications, the staff here should be able to respond to this over the next few days to help further.
