Worst support and speed
Iasonides 8
Message 13 of 13
Been having a steady speed of around 12 mbps for the past 5 months. In the past month chatted with live chat around 4 times. Always end up getting the message where I have the chance to cancel my subscription after 30 days. 30 days pass and I never got that option. Also never got an option of a replacement router like I have seen other customers or an engineer sent out. Anyone else experience something like this?
12 REPLIES 12
Message 1 of 13
Hi Iasonides 8
I've checked the connection stats and your line is in sync at 77.6mb.
Please can you power down the router for a full 30 minutes and then run another speed test?
Message 2 of 13
Have just received the new router. Download speed at 13.2 and upload at 15.3. What do you suggest to do?
Message 3 of 13
Message 4 of 13
Thank you very much. Will let you know the results when I get it
Message 5 of 13
Yeah we’ve tried 3 different routers, factory reset them and changed the MK3 plug from the wall nothing worked
Message 6 of 13
Hi Iasonides 8,
I've ordered the router, it should be with you within a couple of days but please allow up to 5 working days for delivery
Ste_Nix14
Super Duper Contributor
Message 7 of 13
The OCEs will be able the chase this up in the morning for you.
Is it wireless or wired your speed is struggling on?
Steve -
Have you tried turning it off and on again!
Message 8 of 13
I managed to set an appointment with one of your engineers, he came last week and checked the line which indeed sends that speed to the router but the router does not send the appropriate speeds. Next day an open reach engineer came and tested the lines and said they weren’t faulty. That was on Wednesday the 12th of May. He said that the router was faulty and contacted your service to send out a router different to Sagecom. Haven’t received it yet.
Message 9 of 13
Hi Iasonides 8
I've completed a line test which hasn't detected any faults and your line is in sync at 69.9mb.
Can I just check, have you tried powering down the router for a full 30 minutes and then running a speed test once the router has been switched back on?
Message 10 of 13
Thanks I have just updated those.
Message 11 of 13
Hi Iasonides 8,
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 12 of 13
Hi @Iasonides 8,
If you go to the Service Centre what does it show for your estimated speed range. If you log into your router to check your sync speed does this show speeds below that estimated range. If you run a speed test (ideally from both a wired and wireless device so that you can compare), how close are the speed test results to the sync speed shown on your router.
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
