Zoom freezing
BryanM
Chat Champion
Message 10 of 10
I have been using Zoom for 2+ years without a problem.  However, both my last two meetings 'froze'.
Any ideas as to why this has just started to occur?
BryanM (fibre35)
9 REPLIES 9
Message 1 of 10
Message 2 of 10
Thanks for the input Debbie.  Will do this tomorrow p.m. & respond with results.
Cheers
BryanM
Message 3 of 10
Hi Bryan
Could you try factory resetting the router and then testing another Zoom call?
Message 4 of 10
Hi Debbie
Thanks again.  In the first instance, a Zoom session with 5 participants, just turned my video & mike off & listened in on the others.  Ended session in the normal way.  In 2nd instance I was host & ended the meeting.  These are the only two Zoom meetings I have engaged in the period (last 5 days). Have not (not had to) reboot router - is this advised?
Many thanks
BryanM
Message 5 of 10
Hi Skynet_TX
Thanks for picking up on my post.
Answers:
A.  Just Zoom froze - preceeded by bandwidth warning.  Call did not drop - just froze - btw the host also got a bandwidth warning re my connection in the first case, I was host on the second.  Both occurred in the last few days and have been the only Zoom sessions I have engaged.
B. Test run - no issues reported
Cheers
BryanM
Message 6 of 10
Hi Bryan
When the Zoom calls froze did you have to reboot your router or did the connection come back again on its own?
Message 7 of 10
Hi Debbie
Thanks for picking up on my post.  Just Zoom, no other issues.
Cheers
BryanM
Message 8 of 10
Hi Bryan
Is this only affecting Zoom or are you experiencing other issues with the connection too?
Skynet_TX
Message 9 of 10
Hi @BryanM,
Can you explain what you mean by 'froze', did the whole machine freeze, or just the zoom call, did the call completely drop or just 'freeze'.
If you think there might be some issues with your broadband then it would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If you go to the Service Centre what does it show for your estimated speed range. If you log into your router to check your sync speed does this show speeds below that estimated range. If you run a speed test (ideally from both a wired and wireless device so that you can compare), how close are the speed test results to the sync speed shown on your router.
