bad signal
lizahunter85
Message 5 of 5
your wifi signal is ridiculously bad!! please sort asap or im switching providers, for months now it doesnt even stream a movie without constantly buffing & game playing is impossible, your setting keep saying signal is fine but reality is completely different. will definitely not be renewing any contract in april especially when you have the cheek to email saying its going up £2??!! cant even get a signal in my upstairs bedroom
L.Hunter
4 REPLIES 4
Message 1 of 5
Hi lizahunter85,
If you still need assistance can you please add your TalkTalk landline number to your Community Profile as OCE_Debbie requested
Message 2 of 5
Hi lizahunter85
Please can you add your TalkTalk landline number to your Community Profile, we can then look into this further.
SEBSEB
Message 3 of 5
'Your settings keep saying, signal is fine', which settings?, at the risk of stating the obvious have you carried out a speed test/check in order to determine if you are getting the speeds required to download movies?.
Message 4 of 5
Please bear in mind that the reception of WiFi signals within a property is often totally beyond that of any ISP, due to WiFi interference. In addition to this, the location of the router can be critical. As a very general statement, the signal from a router works best on the same floor & the one below, not the one above. So try to make sure that the router is sited as high as possible.
Generally speaking, the 2.4GHz band suffers much more from WiFi interference than the 5GHz band, but the 2.4GHz one can sometimes have a better range, but this all depends on your local area.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
