d-link router
Eliot-davies
Message 3 of 3
I have a 3.5 year old d-link router and an struggling with connection in certain areas of the house.
Anyone having similar issues? Wondering if it's time for a new router as the issue is getting worse especially with the T.V. connection.
Message 1 of 3
Hi Eliot-davies
I can send you a replacement router for testing.
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 3
This is not likely to be down to the router, but more likely, assuming wired (Ethernet) connections are OK, to be WiFi interference.
If you would like me to help you, please can you confirm the make/model of TalkTalk router that you are using - is it the DSL-3782?
