disconnecting same time for the last 2 days
brianthesnail123
Message 2 of 2
Hi there
            our connection has dropped ( only for around 2 minutes ) the same time the last 2 days ( 10-30am) .... prior to this we havent had any problems
            could this be a router issue (hg633) or simply a problem at the exchange
            i would be grateful if a OCE could check my line and report back any problems
                    thanks
brian smy
1 REPLY 1
Message 1 of 2
Hi brianthesnail123,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault. How have you found the stability since your last post? Is the connection still dropping?
