download speed has dropped 50% and im paying for the full speed
matty87081
Message 8 of 8
recently ive been noticing that my download speed is reaching the high 30s instead of advertised speeds of 50-80mbps. only recently this has been happening.ive checked everything i can and restarted my router but nothings changed,i could do with some help if possible.as i need high speeds for work. thank you
mr M george
7 REPLIES 7
Message 1 of 8
What device are you running the speed test on? How many devices are connected to the line? Are they all experiencing slow speeds?
matty87081
Message 2 of 8
I've just switched channels and that didn't seem to change the speed at all. still hovering around the 28 to 30 mark..
mr M george
Message 3 of 8
The line test is still clear and the sync speed still looks good. Have you checked a few different wireless channels to see how the speeds compare?
matty87081
Message 4 of 8
im running them wireless. my router is downstairs and i dont have a laptop to plug into with an ethernet cable.
mr M george
Message 5 of 8
Are you running the speed tests wired or wireless?
matty87081
Message 6 of 8
yeah i tried that with no success. the download speed looks like its capped at no higher than 30mbps and wont go any higher, a few weeks ago i was getting high 70s for the download speed. i just dont know whats wrong.
mr M george
Message 7 of 8
I've run a test on the line which hasn't detected a fault and the sync speed looks ok. Are you running the speed tests wired or wireless? Did you also try powering down the router for a full 30 minutes as this will reset the current session and can often increase the throughput speed?
