on 05-09-2020 05:25 PM
Hello, I have an old dlink dsl 3780 router and I would like to set it as a wifi repeater/extender if possible?
My base router is a Huawei hg633. If it's possible please tell me how (in easy to follow instructions).
on 05-09-2020 07:44 PM
Yes that would work also, thanks for the suggestion.
on 05-09-2020 05:53 PM
Is the powerline adapter solution not possible ?
on 05-09-2020 05:46 PM
Thank you for the reply Martin. No that would be impossible to do in my situation. I was hoping it was possible wirelessly.
I wish I had asked sooner it would have saved me hours of different configurations. Looks like I need a dedicated wifi repeater.
Best Regards.
on 05-09-2020 05:38 PM
That can only be done by connecting the two routers by LAN cable directly OR using powerline adapters to achieve the same.
Is that your plan ?
