on 12-03-2021 11:33 AM
Hi. Just writing this as I am tired of paying for things I am not getting.
Ovear a year and still not getting correct speeds.
Contract : Fibre + fibre boost
What speeds are in this plan? As far as I remember the numbers should oscilate aroung 20Mbit/s upload and 80 Mbit/s download.
My router is never sync for more than:
DS: 56.1 Mbit/s US: 15.0 Mbit/s
Engeener been to my house saying there is all ok, and I suppose if router is syncing at lower speeds its not a issue on "my side".
Need help.
on 17-03-2021 11:10 AM
Hi rejdzik,
Can I just confirm, does the main socket look like the below?
Your guide to main phone sockets
on 17-03-2021 10:19 AM
It doesnt have a test socket I reckon. It has only one socket.
on 17-03-2021 07:13 AM
Morning rejdzik,
I've run a test on the line which is clear. Does your master socket have a test socket? If it does then would it be possible to connect the microfilter and router at the test socket for at least 48hrs so we can see if the speed increases?
on 15-03-2021 09:10 PM
Done.
on 15-03-2021 06:42 AM
Hi rejdzik
Have you added the correct landline number to your Community Profile? (please do not post the number on this thread)
on 12-03-2021 12:27 PM
66MB/s
on 12-03-2021 12:15 PM
That is only the estimate.
What does the results show as minimum guaranteed speed, that is the important number.
on 12-03-2021 12:14 PM
on 12-03-2021 12:13 PM
Service status:
Est. speed: 68 Mb - 74 Mb
Measured speed today: 56 Mb
Router capped at 56MB sync.
on 12-03-2021 11:52 AM
Go to SERVICE CENTRE via the Service Status link at the top of the page.
Perform a speed test and then check the graph for your minimum guaranteed speed.
The service can support an absolute maximum of 80/20 but your personal speed depends on the length of the line to the fibre cabinet.
Very few customers will get 80/20 as you have to be very close to the cabinet to do so.
