fluctuating fibre speeds
dites
Message 10 of 10
Over last couple months or so I've been having trouble with our connection. My mac desktop is connected to the router via lan cable, along with have several other devices (but these are not always in use) We also have a couple phones on wifi. During the last while we've been having extremely varying speeds. While doing  speed tests to monitor, They are fluctuating as high as 49 mbps to as low as 12 mbps. Upload is always constant around 12 mbps.The router light doesn't change from white but during one of my many phone and chat conversations with technical support it was noticed that router had been intermittently disconnecting.
An engineers visit was arranged were he didn't find any issues but did replace the main box to the newest face plate. Since visit still getting the fluctuating speeds but now the highest I see are in the low 30 mbp's.
I've tried all the usual resetting the router and leaving it off for a couple of hours to try and fix it but nothing is helping.
Starting to get very frustrated at getting told the same thing every time I deal with technical support 😞
Thanks very much.
9 REPLIES 9
Message 1 of 10
Hi dites
Message 2 of 10
Hi Chris,
Yes that would be great.
Message 3 of 10
Would you like me to send one? If you let me know we'll get one out to you 🙂
Message 4 of 10
Hi Michelle,
Sorry but I don't have another router I can use to test with.
Message 5 of 10
Hi dites,
Do you have an alternative router that you could test with to rule this out?
Message 6 of 10
Yes I have had several line test's done with the same result as I have been in touch with tech support on numerous occasions. Even while on phone before doing these tests with tech and being asked to do speed checks, the speeds were still fluctuating.
I have the latest wifi hub and the speed definitely increases after rebooting. One time an agent reset router from his side and for a few days I got the best speeds I'd ever seen, then the same problem arose.
Message 7 of 10
Hi dites,
Thanks for confirming this. I've run a test on the line which hasn't detected a fault. The connection looks stable and the sync speed looks consistent. Just to confirm, which router are you using? (make and model) Does the speed immediately increase if you reboot the router?
Message 8 of 10
Hi Chris,
Thanks for reply. There is a slight background noise on telephone but there was a BT engineer out only a few weeks ago. He found one minor issue, one wire was a little bit loose and he replaced the main box with the newest faceplate.
I have two phone sockets but only the master is in use with only the phone and router cables attached.
Davy
Chris-TalkTalk
Message 9 of 10
Hi dites,
Sorry to hear you're experiencing problems with your service. Are you experiencing any problems with your telephone service such as noise on the line?
How many telephone sockets do you have? Do you have anything connected to your telephone socket(s) in addition to your router?
