on 13-07-2018 08:59 PM
Hi guys im having some ridiculous pings at the moment of up to 200ms its usually around 30ms and as you can imagine its affecting vieo calling and gaming massively. also xbox is reporting packet loss. speed is fine at 17mb but theres definetly an issue somehere.
weve always had trouble had about 10 engineers since living here its looking like i need another but im not calling because they dont understand.
on 08-08-2018 01:13 PM
Hi stokeash,
When the connection is sluggish do you have any other devices accessing the internet at the time, could another device be downloading and update or running an automatic backup? Could someone else in the household be accessing the internet?
on 07-08-2018 05:14 PM
on 07-08-2018 12:16 PM
Hi stokeash,
Our Network Team have taken a look and advised that the connection did look unstable up until yesterday. How have you found the stability over the last 24hrs? Do the drops in connection appear to be weather related at all?
on 07-08-2018 08:25 AM
Hi stokeash,
I've requested an update from our Network Team now and I'll let you know as soon as I receive an update back.
on 04-08-2018 02:06 PM
on 03-08-2018 02:30 PM
on 02-08-2018 09:12 AM
Hi stokeash
I've escalated this fault over to our Network Team for investigation.
Please can you post back on this thread tomorrow morning and we can check for further updates on this fault.
on 01-08-2018 03:50 PM
on 01-08-2018 03:43 PM
on 27-07-2018 08:22 AM
Hi stokeash,
Thanks for confirming this. Have you also tested the router at the test socket behind the faceplate and does the connection still drop?
on 25-07-2018 09:10 PM
Hi, only one socket and its a new one recently fitted with the new pull of faceplate without screws.
its literally just the phone and router no sky box or anything and no extensions or wiring just the one main wire in to the master socket which is new as well. the line does come underground from a neighbours property though and could be old?
on 23-07-2018 10:01 AM
Hi stokeash,
How many telephone sockets do you have? What other devices do you have connected in addition to your router?
Does your master socket have a Test Socket?
on 20-07-2018 03:12 PM
hi, yes ive tested and tried everything and multiple routers. upload speed is very low as well its worse than when i had adsl.
on 17-07-2018 06:31 AM
Hi stokeash,
Thanks for the update. Could you also confirm if your master socket has a test socket and if you've recently tested with an alternative router, microfilter and adsl cable?
Once we've confirmed this then we can pass the intermittent connection over to our Network Team for further investigation.
on 16-07-2018 11:27 PM
voice seems fine no crackling or anything like before, but yeah its very unstable it keeps dropping multiple times like twice that i know of i can tell because my whatsapp messages dont send, i have a jitter of 55ms at he moment and pings are all over the place. i think they need to replace some equiptment or some lines or joints or something beacsue its neer been %100 it seems to degrade over time. when fibre was intsalled it was really fast and responsive.
on 16-07-2018 06:47 AM
Hi stokeash,
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault, however the connection looks very unstable and the sync speed appears to be varying.
Just to confirm, is everything ok with the voice service? Are you experiencing any noise on the line?
