high ping jumping randomly
damianero
Message 14 of 14
My internet connection is randomly dropping when I play games ping jumps to 999ms then is going back to normal during 1h of gaming it can happen up to 5 times, I have the same problem when i connect to internet with cable or wifi, I have all bars of signal and my router is next to my pc, I asked for help 4 times now on live help or 45min on the phone, and everytime I am told that the issue was fixed but it isn't. when I run live test check on the talktalk website it doesnt show any issue.
damianero
13 REPLIES 13
Message 1 of 14
Hi damianero,
Ok thanks for confirming and please let us know how you get on 🙂
Message 2 of 14
i have it now I will be testing if it works better thanks
damianero
Message 3 of 14
I've ordered a router, it should be with you within a couple of days but please allow up to 5 working days for delivery
Message 4 of 14
I dont have different router please send one for testing thank you
damianero
Message 5 of 14
Hi damianero,
Ok, do you have a different router that you can test with? If not then we can send a different router for testing purposes to rule this out.
Message 6 of 14
I had internet from different providers before and havent got this issue on different router
damianero
Message 7 of 14
Hi damianero,
Thank you. Can I just confirm, have you ever tested with a different router, just before I pass this to our Network Team?
damianero
Message 8 of 14
damianero
Message 9 of 14
Hi damianero,
Thank you. I've run a test on the line now which hasn't detected a fault and the connection stats looks consistent. Would it be possible to run a wired ping and trace route when the connection is ok and also when this happens and post the results into the thread.
Run a Ping or Traceroute
damianero
Message 10 of 14
done, updated my phone number
damianero
Message 11 of 14
Hi damianero,
  • TalkTalk Telephone number
Message 12 of 14
I have updated my profile info
damianero
Skynet_TX
Message 13 of 14
Hi @damianero,
Then they will hopefully be able to respond to this post within a working day or two.
