message on router
Z-2022
Message 4 of 4
What does the following message mean on router:
DNS name resolution failure?
And what is proton.flurry.com - this is the follow on message from the above.
3 REPLIES 3
Message 1 of 4
Hi Z-2022
The line tests are clear but I think we should send a different make and model of router for testing.
Would you like me to arrange this?
Z-2022
Message 2 of 4
Connection is not always great
Message 3 of 4
Hi Z-2022
Is the connection dropping?
Please can you add your name and TalkTalk landline number to your Community Profile.
