network technician
roberthughes502
Message 3 of 3
i have been without wifi connection for 2 weeks now. i first went through all the connectivity tests with the service helpdesk who sent me a new router. when this did not work either, i was told there was a fault between the exchange and my home given an appointment for an engineer to visit. when they didnt show i contacted the helpdesk who stated that no appointment had been booked and ran me through the same connectivity tests again before stating the case had been referred to a network technician. this leads to the question, what can he do to resolve the problem?
Message 1 of 3
Hi roberthughes502
Openreach are now requesting that this fault is investigated by a line engineer (external investigation)
I have escalated this to Openreach to be investigated by a line engineer and we should receive further updates within the next 48-72hrs.
Skynet_TX
Message 2 of 3
Hi @roberthughes502,
The staff here on the community will be able to take a look at this for you, they will hopefully be able to respond tomorrow. They will be able to run tests on your connection and your router, they will also be able to see if an engineer is already booked to investigate the issue.
What model of router do you have, and what are the LED(s) currently doing ?
