no internet
nicky160
Message 19 of 19
hi, my fibre was installed on 2nd of november. all i have is problem after problem. i had fibre 65. i have called every day since. 1st hub(black) kept blinking orange and white) until friday that week. i had internet for one day. i had new router sent (orange) it worked great until tuesday evening and no internet since(orange light) everytime i call we do all tests etc, never a conclusion. yesterday after same test they will now escalate to management. have to wait another 3 days for anyone to contact me. this is frustrating and terrible. i dont know what to do. im thinking of leaving.
18 REPLIES 18
Message 1 of 19
Hi nicky160,
I've sent you a PM
martswain
Message 2 of 19
@nicky160 forum staff do not work weekends.
nicky160
Message 3 of 19
i havent had response since completing security on friday for engineer to be called out. is there an update.
Message 4 of 19
I'll send you a pm requesting some info to allow us to book an engineer.
nicky160
Message 5 of 19
hello, YES PLEASE ive been asking this for a week. i believe it needs to be openreach because currently next door have them at theirs and everytime he pings them my internet comes on for a minute.
Message 6 of 19
Ok. If all testing has been completed at the main socket with 2 different routers, cables and microfilters and with all other equipment removed from the line, and you're still unable to connect (even wired) then the next step will be to arrange an engineer visit to the property. Would you like to go ahead with this?
nicky160
Message 7 of 19
no it doesnt have test socket
Message 8 of 19
Ok, does your main socket have a test socket? If it does then please can you connect the microfilter, router and phone (if you use a phone) at the test socket please.
Your guide to main phone sockets
nicky160
Message 9 of 19
hello, yes i have the original one sent (black hub) ive tried same process with that also (4 times). still nothing.
Message 10 of 19
Thanks for trying this and I'm sorry to hear this. Do you still have the alternative router?
nicky160
Message 11 of 19
hello, as requested i did this.
still nothing.
thats all that has been happening since days installed. i call talk talk run tests, reset, i reset etc an hour on phone a day. still nothing. awful.
Message 12 of 19
Thanks for confirming. I've re-run the line test again now which is clear and the line is showing in sync, however the router has not authenticated. Have you tried factory resetting the router and then re-setting this back up again?
nicky160
Message 13 of 19
hi, earlier today i tried it with my xbox one but xbox says no internet coming in.
Message 14 of 19
Do you have any device connected to the router with a cable (wired) such as a pc etc ?
nicky160
Message 15 of 19
router is plugged in. wires are correct (please remember one moment wifi comes on then off again)
its on orange, not flashing. does not work even if items are plugged.
Message 16 of 19
I'm showing your router connected at the moment.  Are you only using devices over WiFi ?  Do you have any device you can connect wired ?
nicky160
Message 17 of 19
hi, ive just updated it.
Message 18 of 19
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
