on 22-01-2022 11:27 AM
Dear Sir/Madam
No sure what is going on with my connection now, very very poor service i am getting on .
I was just under 17mbps for 3 to 4 days and this morning 2 mbps, tested with 2 routers.
on 25-01-2022 07:09 AM
I've included a Help Guide below,
on 24-01-2022 10:37 AM
on 24-01-2022 10:30 AM
Please Sir.. do what ever fix it
This is my last chance today with this poor service
on 24-01-2022 10:20 AM
Hi Slowconnection
Would you like us to run the line test again first between 1-3pm or just arrange an engineer visit now?
on 24-01-2022 10:06 AM
please do re-book the engineer ASAP.
Wasted plenty of my time with this service already
on 24-01-2022 10:05 AM
We've found a fault and need to send an Openreach engineer to your home to fix it. We're really sorry if this is causing issues with your service.
To book an appointment, please login with your username and password here
Thank you for your patience.
Your TalkTalk team
on 24-01-2022 10:00 AM
Thanks for confirming. We will re-run the line test again between 1-3pm and will post back as soon as this has completed.
24-01-2022 09:58 AM - edited 24-01-2022 09:58 AM
Dear Sir.. I have wasted plenty of time with this poor service now.
I bought your service to work for me not I work for it.
i will reconnect to the test socket between 13:00 and 15:00 UK time
This is my LAST chance. if it is not fix fully . I am out from here.
on 24-01-2022 07:34 AM
I'm sorry to hear this and I will take a look now. I've run a test on the line which has detected a potential fault. Does your main socket have a test socket? If it does then if possible please can you connect the microfilter, router and phone at the test socket so we can re-run the line test in this set up. Is the voice service also ok with no noise on the line?
