port forwarding
vicka1949
Message 2 of 2
Hi guys, I have a sagemcom-fast 5364 router and need to open and forward port 8000 to a dvr on my network.Can anyone tell me how to do this please..Many thanks in advance.vicka1949.
Vicka
1 REPLY 1
Message 1 of 2
First, allocate your DVR a DHCP reserved IP address, this is done via:-
Dashboard > Manage my devices > Manage advanced settings
Click on the device in question & use the Device Info tab.
Then use the Port Forwarding tab for that device. Then set up a rule like this:-
Customer Service Name: something unique e.g. DVR
Service: Other
External Host: leave this field blank or insert an asterisk character (*)
Internal Host: this should already be set to the IP address of your DVR.
Protocol: TCP (I assume that this is TCP & not UDP - that is down to you to find out).
External Port: 8000
Internal Port: 8000
Click Apply.
You should consider the use of a DDNS provider.
