question for those in the know
kkkev11
Whizz Kid
Message 6 of 6
hi anybody is it possible for a card reset to affect dlm and or fibre download upload speeds thanks in advance
wizard
5 REPLIES 5
Message 1 of 6
I'll take a look at your other thread now.
Message 2 of 6
there is know noise o c e s already know its just network team told me it would not have any affect on fibre speed or the dlm  like i say oces allready know thanks
wizard
Message 3 of 6
Yes it does, thanks. I take it there is no noise on the line you can hear?  Other than that let's see what the OCE have to say when they pick this up.
Message 4 of 6
i had single ringtone was not fixed so they did card reset  and fixed it next day speed dropped right down for several hours then came back but slightly lower ok for two weeks then dropped tt did all checks but they say speed to router is ok network team did more tests speed dropped even lower everything in home tested from master socket still same but they want bright spark visit now  hope that makes sense thanks
wizard
Message 5 of 6
Maybe! Can you give us a bit more context?
