"Cannot connect to network" on 2.4GHz
Paulsteed
Message 2 of 2
I have a Sagemcom TalkTalk WI-FI hub and am having trouble connecting to the 2.4GHz network from my iPhone 12. I get the above message but instead of the 2.4 it gives me the nameof my SSID.
I have looked at older articles and changed the channel to 1 and made bandwith 20MHz. I have rebooted my iPhone and still cannot connect to the network. It is just my phone. My laptop and my iPad will connect with no issues.
Why do I need to connect? Because I have Wi-Fi plugs on the 2.4 network and need to connect my phone in order to manage them or add new devices.
Please advise.
Many thanks
Paul
1 REPLY 1
Message 1 of 2
The problem is that you do not know how good channel 1 is.
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
