on 25-05-2022 08:30 PM
hi
TalkTalk Wi-Fi Hub
version SG4K100136
hardware version FAST5364 3.00
software version SG4K100136
VPN configured is PPTP
on 27-05-2022 02:48 PM
Hi Rob
I'm so glad to hear this, thanks for letting us know 🙂
on 27-05-2022 02:46 PM
it all works now
thank you
on 27-05-2022 02:22 PM
Hi Rob
Yes please 🙂
on 27-05-2022 02:21 PM
thank you i will do that now - do you mean just swithch it off and then back on again?
on 27-05-2022 10:09 AM
Hi Rob
All done 🙂
Please can you power down the router and then retest once the router is switched back on.
Please don't factory reset the router.
on 27-05-2022 09:15 AM
Hi Rob
Apologies, I'm having some issues updating the FW.
I will keep trying this and confirm once the router firmware has updated. Please can you leave the router switched on without being rebooted.
on 27-05-2022 09:02 AM
yes thank you
on 27-05-2022 07:24 AM
Hi Rob
Thank you. I will post back to confirm once the firmware has updated.
Debbie 🙂
on 27-05-2022 07:23 AM
hi, thanks Debbie, yep thats fine, the router is switched on and wont be switched off, please message if you need us to do anything elseor call the landline, thanks
on 27-05-2022 06:59 AM
Hi robhansel
Will it be ok if I start the update at 9am today?
on 26-05-2022 08:04 PM
hi Debbie, thanks for getting back to us so quick, anytime convenient for you, the router can always be switched on, evening is best though, but we can do daytime if needs be. Let me know a time. Thank you
on 26-05-2022 06:13 AM
Hi robhansel
I will need to make a change to your router firmware, when would be the best time to do this?
We advise to leave the router switched on without being rebooted whilst we update the FW, this should take no longer than 15 minutes to update.
on 25-05-2022 09:11 PM
Sorry that you have had problems with this, the support team here can help. You should get response tommorow.
