router drops connection every night at 12-1am and light begins flashing
dannykebab
Message 12 of 12
Hi every night my router drops connection about 12-1am and the light starts flashing. the disconnect doesnt last long and after 30 seconds or so the light goes solid white again please can somebody investigate this problem as it is very annoying
11 REPLIES 11
Message 1 of 12
I've run a test on the line now which hasn't detected a fault and I can only see 1 re-connection on the line. Can I just confirm, are you using HomeSafe/KidSafe? Do you have any devices set on a timer to come on/off around the same time that this happens? Is the voice service affected at the same time?
deasson58
Message 2 of 12
Talktalk is scanning your profile and resetting your overall speed..will bet your speed drops a min of 2mbps within a few days!!
Danny Easson (Victim of Speed)
Message 3 of 12
added my number cheers
Message 4 of 12
Hi dannykebab
Please add your home number to your 'Community Profile' . If unsure of the number, you can dial 17070 from your home phone.
Fuzzrab
Message 5 of 12
@martswain Thanks for the info. Have changed the settings. So hopefully don't get this from now on.
Gliwmaeden2
Message 6 of 12
@dannykebab, personal information details must never be displayed in the public thread.
You just need to check that they are saved correctly in the profile area.
Go via your avatar/name; settings; from the drop down menu that starts with "email" choose Personal Information and check that the landline number is correct and matches both the number in your account and the number that is read back if you dial 17070 from your landline.
If it differs, put that in Private Notes at the end of the Personal Information section.  SAVE CHANGES.
Karl is unlikely to reply over the weekend. Check back on Monday.
I've moved your duplicate post out of the way.
@Fuzzrab, please start your own thread, if you haven't yet done so. You need to return to the message board and click on "start a topic". Staff only reply to the original poster.
Message 7 of 12
@dannykebab Please check the number on your personal profile and amend as appropriate, you should never post such information on the public forums.
Message 8 of 12
Hi karl when i log into my account the number displayed is as follows: XXXXX
NUMBER REMOVED FOR SECURITY REASONS.
Message 9 of 12
Hi dannykebab
Can you check the home phone number on your profile is correct, I'm not finding a service with that number.
martswain
Message 10 of 12
@dannykebab  and @Fuzzrab
Sounds like the infamous HOMEWORK TIME glitch.
Go to your Homesafe settings and check.
https://community.talktalk.co.uk/t5/Articles/How-to-use-HomeSafe/ta-p/2205196
Fuzzrab
Message 11 of 12
I have the same problem. Not every night for me thankfully but at least every 4 odd days. It'd be nice to get an answer to this. Though my connection usually drops for the whole hour. Router reset/resart doesn't do anything.
