router problems
fourboys
Message 20 of 20
Hi, I have recently, 12 days ago, been upgraded to Fibre 35 and have encountered problems since then. Firstly, if not actually using the internet for a while my devices lose connection, secondly, when streaming or downloading TV or music I am getting a lot of buffering. If I turn the router off and on again this helps. I checked my speeds online and it said all was OK with my connection. I chatted with a TALKTALK representative online and they advised me to reset the router. The problem is I do not know what to do after resetting the router. I have tried to look online and it says, do not reset if you don't know how to configure, which I don't. Has anyone any idea what I should do? thank you in anticipation
19 REPLIES 19
Message 1 of 20
Hi fourboys,
Thanks for the information, yes could you try the new router again please and let us know how you get on
Message 2 of 20
Hi Debbie, yes I am using the HG633 router at present but I am really not happy. I now have two routers, the new one was OK, not really better than the old one but my desktop was really slow with it. I reverted to the old one, reset it, again, and it seemed OK as long as it was switched off and one again every morning. Last night I was trying to watch BBC iplayer and it was buffering continuously, I had to switch the router off and on again to be able to finish the programme. Now I'm thinking, should I try the new one again? The speed to my desktop is terrible this morning, slightly better on my phone?? Again, I can only say this did not happen before talktalk switched me to fibre 35.
Message 3 of 20
Hi fourboys
Are you using the HG633 router at the moment?
Message 4 of 20
Hi Michelle, thanks for your help. The problem appears on all devices, but not all of the time. I have found that switching the router off then on again, no matter which router, seems to solve the problem. At least I have been able to stream TV without buffering, that is really annoying. I am not too worried about the speed, the speed was fine before I was switched on to fibre 35, so I am prepared to live with what I have, at least it is doing what I want it to do. Thanks again for everyone's help.
Message 5 of 20
Thanks for confirming. If the connection improves after rebooting the router then this would suggest a possible router issue, however I can see from your post that you've tested with a different router. Can I just confirm, does this happen on more than one device?
Message 6 of 20
Hi Chris, yes, the talk talk page opens slowly on all devices. It is working not too bad this morning as I have switched the router off then on again.
Message 7 of 20
Hi fourboys,
Does the TalkTalk page refuse to open on more than one device? Does it still refuse to open if you reboot your router?
Message 8 of 20
Hi Chris, sorry for the late reply but for days now the talktalk page has refused to open?? My desktop is connected with ethernet cable as I read that this was the best way. At the moment I have replaced the previous router and as long as I switch it off then on again it is working reasonably well, at least as it was before switching to fibre 35. I have said previously that I did not have any problems prior to this switch, that happened at the beginning of April, maybe things will settle down again. Thanks for your input.
Message 9 of 20
Hi fourboys,
Thanks for the information. The line test is clear and your router is now in sync at 39.2Mbps, could I just ask, how does your desktop connect to the router, Ethernet cable or WiFi?
Message 10 of 20
Hi Debbie, I have looked into what you suggested and I'm afraid it is beyond me. Like I have said, I am not tech minded and I can't make sense of this. To be honest, I am afraid to try in case I lose what I have. What I can say is that my devices are not losing their connection to the router when they are switched off now. My TV is still buffering at times, and sometimes the internet seems to run very slow, especially on the desktop. I am able to use the internet most of the time but I can honestly say that since switching to fibre, it is not as stable as it used to be. As I had no choice but to switch I fear I must live with it. Thank you for all you have tried to do to help.
Message 11 of 20
Hi fourboys
Have you also tried splitting the SSID's? Split your router's SSID (wireless network name)
Message 12 of 20
Hi Debbie, I have been reluctant to reply to you as my experience lately has been mixed. First, I do not now seem to lose connections if not on the internet for a while, that is good. I am still getting a little buffering when watching smart TV, this can be annoying. My speeds to my PC are still fairly poor but my speeds to my laptop seem to be reasonable. I'm not sure what is happening but again I can only say that before going to 'fast fibre 35 speed broadband' I did not have these problems. Have you any ideas further? thank you
Message 13 of 20
Hi fourboys
Apologies for this.
I have ordered the replacement router, please allow 24-48hrs for this to arrive.
Message 14 of 20
Hi Debbie, so sorry for the late reply but I have been experiencing problems again. Yes please, I would appreciate a new router as things are no better after factory reset. Thank you very much
Message 15 of 20
Hi fourboys
How has the connection been since the factory reset?
Would you like me to send a replacement router for testing to see how the connection compares?
fourboys
Message 16 of 20
Thank you so much for that, the router is actually a Huawei HG633, so I will try what you have said. I was really worried that it would be more complicated as you can guess, I am not tech minded.
Message 17 of 20
Ok.
If you hold in the reset pin for say 15 seconds minimum  you will see led light flash when actioned.
It will then just reboot as normal. (back to same state it came out of box)
It will not effect any thing you do.  You will have to change nothing
Router will boot as normal and your access will be the same
If you get same issue afterwards.
Then state the router type and model.
Sounds like it is a SageMcom Fast 5364 on firmware level 2816t
fourboys
Message 18 of 20
Thank you, I have tried that and it works well for a short while. The TALKTALK agent I chatted with asked me to reset the router with a pin in the back of the router where it says reset. I am not sure on that, I don't know what |I have to do if the router is reset to factory settings.
paulshent
Message 19 of 20
If it was suggested that you turn router off then all you have to do is
Power off router.
Wait for 30 mins and then power it back on.
After a little wait it will connect to Internet service.
Light on front will turn from Orange to steady white
That is it.  You DO NOT have to do anything else
