router security warning intrusion
mike214
Message 3 of 3
So over the past week or so i've been experiencing a lot of slow download speeds and also been getting kicked off the network then re-connected only to be disconnected again 2 mins later, i tried resetting the router but that didn't help, at first i thought it may have been talktalk working on the line but after 4 or 5 days of putting up with it alarm bells started ringing so i decided to check my router logs to see if the issue was with the router only to find all this going off and have no clue what to do. So any help would be much appreciated. Many thanks in advance Mike.
Manufacturer:Huawei Technologies Co., Ltd.
Product Style:HG633
Serial Number:C4R8W16B23012913
Hardware Version:H.1.01
Software Version:v2.00t
2021-11-16 18:06:48 Security Warning Intrusion -> src=89.248.165.203 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=13608 PROTO=TCP SPT=57729 DPT=60001 WINDO
2021-11-16 17:57:15 Security Warning Intrusion -> src=89.248.165.166 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=29808 PROTO=TCP SPT=40530 DPT=23902 WINDO
2021-11-16 17:52:51 User Level Notice User admin login from 192.168.1.11 successfully.
2021-11-16 17:52:26 WIFI Notice CC-73-14-69-65-AD-Wireless CC:73:14:69:65:AD is connected.
2021-11-16 17:52:20 WIFI Notice CC-73-14-69-65-AD-Wireless CC:73:14:69:65:AD is disconnected.
2021-11-16 17:51:34 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is connected.
2021-11-16 17:51:34 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is disconnected.
2021-11-16 17:51:34 WIFI Notice CC-73-14-69-65-AD-Wireless CC:73:14:69:65:AD is connected.
2021-11-16 17:51:34 WIFI Notice CC-73-14-69-65-AD-Wireless CC:73:14:69:65:AD is authenticated failed:authentication rejected due to timeout.
2021-11-16 17:51:34 WIFI Notice Andrews-iPhone-Wireless DE:CA:93:90:4A:86 is connected.
2021-11-16 17:51:33 WIFI Notice BC:30:7D:ED:28:86 is connected.
2021-11-16 17:51:28 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is connected.
2021-11-16 17:51:28 WIFI Notice Andrews-iPhone-Wireless DE:CA:93:90:4A:86 is disconnected.
2021-11-16 17:51:16 User Level Notice User admin(192.168.1.11) modify WLANConfiguration.RegulatoryDomain; WLANConfiguration.TransmitPower; WLANConfiguration.X_WlanStandard; WLANConfiguration.X_Wlan11NHtMcs; WLANConfiguration.X_Wlan11NGIControl; WLANConfiguration.X_Wlan11NBWControl; WLANConfiguration.MaxBitRate; WLANConfiguration.WMMEnable; WLANConfiguration.AutoChannelEnable; WLANConfiguration.Channel; WLANConfiguration.RegulatoryDomain; WLANConfiguration.TransmitPower; WLANConfiguration.X_WlanStandard; WLANConfiguration.X_Wlan11NHtMcs; WLANConfiguration.X_Wlan11NGIControl; WLAN.
2021-11-16 17:50:04 User Level Notice User admin login from 192.168.1.11 successfully.
2021-11-16 17:48:06 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is connected.
2021-11-16 17:48:03 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is disconnected.
2021-11-16 17:46:25 Security Warning Intrusion -> src=94.102.49.193 DST=92.21.25.174 LEN=44 TOS=0x00 PREC=0x00 TTL=122 ID=22667 PROTO=TCP SPT=23320 DPT=3780 WINDOW=
2021-11-16 17:39:16 User Level Notice User admin login from 192.168.1.11 successfully.
2021-11-16 17:39:07 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is connected.
2021-11-16 17:39:06 WIFI Notice Andrews-iPhone-Wireless DE:CA:93:90:4A:86 is connected.
2021-11-16 17:37:37 User Level Notice User admin login from 192.168.1.11 successfully.
2021-11-16 17:36:57 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is connected.
2021-11-16 17:36:55 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is disconnected.
2021-11-16 17:36:25 Security Warning Intrusion -> src=120.232.41.62 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=240 ID=22344 PROTO=TCP SPT=45527 DPT=11111 WINDOW
2021-11-16 17:36:23 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is connected.
2021-11-16 17:35:46 WIFI Notice BC:30:7D:ED:28:86 is connected.
2021-11-16 17:34:32 WIFI Notice Andrews-iPhone-Wireless DE:CA:93:90:4A:86 is connected.
2021-11-16 17:34:32 WIFI Notice BC:30:7D:ED:28:86 is connected.
2021-11-16 17:34:25 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is disconnected.
2021-11-16 17:26:35 Security Warning Intrusion -> src=46.198.230.150 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=21371 PROTO=TCP SPT=60736 DPT=52869 WINDOW
2021-11-16 17:26:28 WIFI Notice Andrews-iPhone-Wireless DE:CA:93:90:4A:86 is connected.
2021-11-16 17:26:27 WIFI Notice BC:30:7D:ED:28:86 is connected.
2021-11-16 17:26:21 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is connected.
2021-11-16 17:23:43 WIFI Notice BC:30:7D:ED:28:86 is connected.
2021-11-16 17:23:37 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is connected.
2021-11-16 17:22:58 WIFI Notice BC:30:7D:ED:28:86 is connected.
2021-11-16 17:22:18 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is connected.
2021-11-16 17:21:49 WIFI Notice BC:30:7D:ED:28:86 is connected.
2021-11-16 17:21:40 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is connected.
2021-11-16 17:21:09 WIFI Notice BC:30:7D:ED:28:86 is connected.
2021-11-16 17:16:22 Security Warning Intrusion -> src=154.89.5.66 DST=92.21.25.174 LEN=44 TOS=0x00 PREC=0x00 TTL=247 ID=52886 PROTO=TCP SPT=49005 DPT=8081 WINDOW=10
2021-11-16 17:15:02 WIFI Notice BC:30:7D:ED:28:86 is connected.
2021-11-16 17:10:33 Security Warning ACCEPT UDP SAMBA Request
2021-11-16 17:10:30 WIFI Notice DESKTOP-96LJGIK-Wireless 1C:BF:CE:1F:4F:BC is connected.
2021-11-16 17:10:19 WIFI Notice BC:30:7D:ED:28:86 is connected.
2021-11-16 17:06:26 Security Warning Intrusion -> src=23.95.132.46 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=240 ID=29277 PROTO=TCP SPT=41983 DPT=34166 WINDOW=
2021-11-16 17:01:22 Security Warning DROP TCP SAMBA Request
2021-11-16 17:00:24 WIFI Notice CC-73-14-69-65-AD-Wireless CC:73:14:69:65:AD is connected.
2021-11-16 16:56:22 Security Warning Intrusion -> src=185.194.60.97 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=48959 PROTO=TCP SPT=23265 DPT=23 WINDOW=530
2021-11-16 16:46:37 Security Warning Intrusion -> src=159.65.99.90 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=20492 PROTO=TCP SPT=47122 DPT=1369 WINDOW=1
2021-11-16 16:36:58 Security Warning Intrusion -> src=46.148.20.13 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=238 ID=48622 PROTO=TCP SPT=60000 DPT=7229 WINDOW=1
2021-11-16 16:26:43 Security Warning Intrusion -> src=89.248.165.97 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=5649 PROTO=TCP SPT=47247 DPT=24460 WINDOW=
2021-11-16 16:16:20 Security Warning Intrusion -> src=89.248.165.97 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=49435 PROTO=TCP SPT=47247 DPT=24058 WINDOW
2021-11-16 16:06:31 Security Warning Intrusion -> src=167.248.133.78 DST=92.21.25.174 LEN=44 TOS=0x00 PREC=0x00 TTL=36 ID=54158 PROTO=TCP SPT=29274 DPT=2525 WINDOW=
2021-11-16 15:56:26 Security Warning Intrusion -> src=89.248.165.53 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=47939 PROTO=TCP SPT=53859 DPT=9003 WINDOW=
2021-11-16 15:46:42 Security Warning Intrusion -> src=89.248.165.166 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=61929 PROTO=TCP SPT=47223 DPT=23863 WINDO
2021-11-16 15:36:38 Security Warning Intrusion -> src=79.124.62.62 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=15537 PROTO=TCP SPT=54585 DPT=3389 WINDOW=1
2021-11-16 15:26:18 Security Warning Intrusion -> src=80.85.84.75 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=249 ID=29895 PROTO=TCP SPT=45684 DPT=5900 WINDOW=10
2021-11-16 15:16:24 Security Warning Intrusion -> src=34.96.130.4 DST=92.21.25.174 LEN=44 TOS=0x00 PREC=0x00 TTL=250 ID=23536 PROTO=TCP SPT=53790 DPT=3306 WINDOW=10
2021-11-16 15:06:31 Security Warning Intrusion -> src=193.242.145.101 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=239 ID=53411 PROTO=TCP SPT=50070 DPT=6142 WINDO
2021-11-16 14:56:16 Security Warning Intrusion -> src=89.248.165.120 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=23928 PROTO=TCP SPT=54243 DPT=3399 WINDOW
2021-11-16 14:46:19 Security Warning Intrusion -> src=192.241.203.205 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=54321 PROTO=TCP SPT=50758 DPT=50000 WIND
2021-11-16 14:36:31 Security Warning Intrusion -> src=193.242.145.101 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=239 ID=62748 PROTO=TCP SPT=50070 DPT=5076 WINDO
2021-11-16 14:26:19 Security Warning Intrusion -> src=223.71.167.164 DST=92.21.25.174 LEN=44 TOS=0x00 PREC=0x00 TTL=114 ID=29916 PROTO=TCP SPT=43769 DPT=2082 WINDOW
2021-11-16 14:16:19 Security Warning Intrusion -> src=104.206.128.74 DST=92.21.25.174 LEN=44 TOS=0x00 PREC=0x00 TTL=239 ID=54321 PROTO=TCP SPT=49557 DPT=2087 WINDOW
2021-11-16 14:06:21 Security Warning Intrusion -> src=45.146.165.209 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=50957 PROTO=TCP SPT=55715 DPT=6389 WINDOW
2021-11-16 13:56:29 Security Warning Intrusion -> src=198.144.159.78 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=36356 PROTO=TCP SPT=48551 DPT=1465 WINDOW
2021-11-16 13:52:57 WIFI Notice 38:A6:CE:37:4D:E6 is disconnected.
2021-11-16 13:52:55 WIFI Notice 3A:D3:67:1B:4D:E2 is authenticated failed.
2021-11-16 13:46:36 Security Warning Intrusion -> src=91.191.209.146 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=8625 PROTO=TCP SPT=43037 DPT=5013 WINDOW=
2021-11-16 13:36:37 Security Warning Intrusion -> src=91.239.130.31 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=61339 PROTO=TCP SPT=58444 DPT=8090 WINDOW=
2021-11-16 13:27:07 Security Warning Intrusion -> src=198.144.159.78 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=57214 PROTO=TCP SPT=48551 DPT=1468 WINDOW
2021-11-16 13:16:28 Security Warning Intrusion -> src=198.144.159.22 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=47589 PROTO=TCP SPT=48770 DPT=4286 WINDOW
2021-11-16 13:15:13 Security Warning Detect UDP port scan attack, scan packet from 184.105.247.194.
2021-11-16 13:06:28 Security Warning Intrusion -> src=162.142.125.168 DST=92.21.25.174 LEN=44 TOS=0x00 PREC=0x00 TTL=41 ID=25256 PROTO=TCP SPT=26984 DPT=836 WINDOW=
2021-11-16 12:56:28 Security Warning Intrusion -> src=193.27.229.184 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=52657 PROTO=TCP SPT=42119 DPT=3399 WINDOW
2021-11-16 12:46:22 Security Warning Intrusion -> src=189.29.61.159 DST=92.21.25.174 LEN=44 TOS=0x00 PREC=0x00 TTL=47 ID=21124 PROTO=TCP SPT=49841 DPT=26 WINDOW=613
2021-11-16 12:36:59 Security Warning Intrusion -> src=193.57.40.49 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=42675 PROTO=TCP SPT=53571 DPT=3375 WINDOW=1
2021-11-16 12:26:27 Security Warning Intrusion -> src=192.241.210.4 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=54321 PROTO=TCP SPT=34064 DPT=9200 WINDOW=
2021-11-16 12:16:27 Security Warning Intrusion -> src=80.82.70.228 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=23777 PROTO=TCP SPT=60000 DPT=16464 WINDOW=
2021-11-16 12:06:49 Security Warning Intrusion -> src=198.144.159.78 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=36483 PROTO=TCP SPT=48538 DPT=1240 WINDOW
2021-11-16 11:56:44 Security Warning Intrusion -> src=198.144.159.110 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=58463 PROTO=TCP SPT=49269 DPT=2312 WINDO
2021-11-16 11:46:21 Security Warning Intrusion -> src=198.144.159.22 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=15810 PROTO=TCP SPT=48763 DPT=1713 WINDOW
2021-11-16 11:36:53 Security Warning Intrusion -> src=167.94.138.84 DST=92.21.25.174 LEN=44 TOS=0x00 PREC=0x00 TTL=37 ID=42740 PROTO=TCP SPT=27783 DPT=12319 WINDOW=
2021-11-16 11:26:36 Security Warning Intrusion -> src=185.12.179.224 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=27143 PROTO=TCP SPT=41527 DPT=1111 WINDOW
2021-11-16 11:16:34 Security Warning Intrusion -> src=198.144.159.110 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=30620 PROTO=TCP SPT=49263 DPT=2213 WINDO
2021-11-16 11:06:19 Security Warning Intrusion -> src=185.191.34.207 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=7020 PROTO=TCP SPT=53719 DPT=36740 WINDOW
2021-11-16 10:58:27 Security Warning DROP UDP SAMBA Request
2021-11-16 10:56:28 Security Warning Intrusion -> src=198.144.159.22 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=4846 PROTO=TCP SPT=48770 DPT=3132 WINDOW=
2021-11-16 10:46:34 Security Warning Intrusion -> src=89.248.165.97 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=6004 PROTO=TCP SPT=47247 DPT=24330 WINDOW=
2021-11-16 10:43:25 Security Warning DROP FTP Request
2021-11-16 10:37:39 Security Warning Intrusion -> src=192.241.209.147 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=54321 PROTO=TCP SPT=46393 DPT=5432 WINDO
2021-11-16 10:26:43 Security Warning Intrusion -> src=23.148.145.233 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=25839 PROTO=TCP SPT=46630 DPT=8080 WINDOW
2021-11-16 10:16:35 Security Warning Intrusion -> src=198.144.159.110 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=40595 PROTO=TCP SPT=49281 DPT=2580 WINDO
2021-11-16 10:06:16 Security Warning Intrusion -> src=221.124.71.135 DST=92.21.25.174 LEN=52 TOS=0x00 PREC=0x00 TTL=107 ID=48912 DFPROTO=TCP SPT=62100 DPT=44485 WIN
2021-11-16 09:56:16 Security Warning Intrusion -> src=89.248.165.241 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=33293 PROTO=TCP SPT=56541 DPT=14873 WINDO
2021-11-16 09:46:21 Security Warning Intrusion -> src=216.218.206.100 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=54321 PROTO=TCP SPT=46879 DPT=9000 WINDO
2021-11-16 09:36:33 Security Warning Intrusion -> src=89.248.165.97 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=35965 PROTO=TCP SPT=47247 DPT=24403 WINDOW
2021-11-16 09:26:57 Security Warning Intrusion -> src=159.65.109.88 DST=92.21.25.174 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=16710 PROTO=TCP SPT=47107 DPT=1881 WINDOW=
Message 1 of 3
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 2 of 3
Hi @mike214,
The intrusion warnings are probably nothing to worry about, they are just your router logging the fact that the built in firewall has blocked some incoming traffic, it is perfectly normal.
In terms of the connection issues, is your router dropping the connection to the internet (i.e. the 'Broadband' light going out and then flashing as it reconnects).
Do you have any devices connected 'wired', or are all of your devices wireless, if you have some wired devices do they also have these connectivity problems.
If your router is not dropping its internet connection, and if only wireless devices are affected, then you may be suffering from Wi-Fi interference.
You could try changing the channels that your router broadcasts the Wi-Fi signal on, you can use free smartphone Apps like this to see what channels are being used within range of your smartphone, you can then change your router to use channels that are less congested.
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
