slow speed from router to device
Adriana4
Message 32 of 32
Can anyone help me with that? I am experiencing  low speed from few days ago now. I've tried everything. People from the chat were doing the tests but nothing helped and the chat was just ending in the middle of the conversation.
Adriana
31 REPLIES 31
Message 1 of 32
Hi Adriana4
I'm just sending you a Private Message to confirm some details so we can arrange the engineer visit.
Adriana4
Message 2 of 32
@Michelle-TalkTalk  The engineer visit would be great. Please, make an appointment. I am not using any adapters. Unfortunately, I can not dial it from my phone as I don't get anything else than a router. So even if I have it within my package, I didn't get any phone or tv box.
Adriana
Message 3 of 32
Ideally it would need to be a wired test. As everything looks ok from here would you like us to arrange a TalkTalk Engineer Visit to visit so that they can run some checks in the property, including some wired speed tests? Can I also just confirm if you're using any powerline adapters? Can you also dial 17070 from your home phone and confirm if the correct telephone number is read back please as this will rule out a possible crossed line. Please do not post any personal information on the Community.
Adriana4
Message 4 of 32
The only device connected wired is my tv. Can I do it on wireless device? @Michelle-TalkTalk
Adriana
Message 5 of 32
Thank you. This still looks really low based upon the current sync speed. Please can you run a wired pings and trace routes and post the results into the thread.
Run a Ping or Traceroute
Adriana4
Message 6 of 32
@Debbie-TalkTalk  I just run a speed check on wired device and the results are as follow: 8.5 Mbps Average Download Speed and 0.7 Mbps Average Upload Speed
Adriana
Message 7 of 32
Hi Adriana4
Can you run a wired speed on any device?
Adriana4
Message 8 of 32
I was on wireless. Just checked on my phone, the results are as follow: 6.8 Mbps-average download speed and 3.7Mbps average upload speed.
Just also checked on my laptop (also wireless), the results are as follow: 6.6Mbps-average download speed and 3.6Mbps-average upload speed.
Adriana
Message 9 of 32
Hi Adriana4
Was this on a wired device and have you tested a different device?
Adriana4
Message 10 of 32
hi @Debbie-TalkTalk
You can see the results above. Also, which router should I send back to you? Do think the engineer appointment is the next thing we need to do?
Adriana
Adriana4
Message 11 of 32
@Debbie-TalkTalk
 I shut the power down but the results are similar. (see the attachment)
Adriana
Message 12 of 32
Adriana4
Message 13 of 32
yes @Debbie-TalkTalk . Will get back to you in 30mins.
Adriana
Message 14 of 32
Hi Adriana4
Please can you power down the new router for 30 minutes also, this will start a new session.
Adriana4
Message 15 of 32
Good afternoon @Debbie-TalkTalk
 New router just came in. I did everything as in the instruction and run the speed check. The results are similar to those before. (see attachment)
Adriana
Message 16 of 32
Adriana4
Message 17 of 32
@Debbie-TalkTalk  Thank you. I will be back after I checked new one.
Adriana
Message 18 of 32
Hi Adriana4
You usually receive a text message.
Adriana4
Message 19 of 32
@Debbie-TalkTalk  Thanks a lot! Will I get any email with confirmation that new router is on its way?
Adriana
Message 20 of 32
Hi Adriana4
No problem 🙂
Let us know how the connection/speed compares with this router.
