slow speeds after Broadband fault
skippy70
Message 26 of 26
We had no broadband one day last week for most of the day & talktalk sent an engineer to the exchange its working again now but my speed is allover the place & has dropped dramatically also getting high pings when doing speed tests usual speeds are about 58  had no problems in all the time i have been with talk talk but cant even watch youtube without it stuttering could someone look into this please for me
router is HG 633
cant see anything different in the router sats
Up
Connection status:
Showtime
Upstream line rate (kbit/s):
14811
Downstream line rate (kbit/s):
57321
Maximum upstream rate (kbit/s):
14208
Maximum downstream rate (kbit/s):
76672
Upstream noise safety coefficient (dB):
5.6
Downstream noise safety coefficient (dB):
6.4
Upstream interleave depth:
1
Downstream interleave depth:
1663
Line standard:
VDSL2
Upstream line attenuation (dB):
0.1
Downstream line attenuation (dB):
12.5
Upstream output power (dBm):
6.8
Downstream output power (dBm):
11.9
Channel type:
Interleaved
DSL up-time:
0 days 18 hours 14 minutes 27 seconds
25 REPLIES 25
Message 21 of 26
test onetest one
Message 22 of 26
Thanks for getting back to me, hope you're feeling better
Can you please run a couple of speed tests at lest 10 minutes apart on the My Account speed checker on a device connected by Ethernet cable to your router (can you try to make sure that no other devices/applications accessing the internet at the time)
Message 23 of 26
sorry i havent answered till now but i have been poorly so not been on the speeds have been varying between 3 - 18 but 18 has been the fastest,I have tested both wireless & wired.just tested again & it was 6MB down
Chris-TalkTalk
Message 24 of 26
Hi skippy70,
How are you getting on, are you still experience the poor performance? Do you experience the poor performance on devices connected to your router by Ethernet cable (if you have any)?
Message 25 of 26
You are getting a downstream line rate of 57M, which is way more than enough to watch any youtube video. What sort of speed test results do you get on wired or wireless connections?
